175 pistons in d17 gas?
vyvyjim View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote vyvyjim Quote  Post ReplyReply Direct Link To This Post Topic: 175 pistons in d17 gas?
    Posted: 25 Aug 2011 at 6:53am
My series IV D17 needs an engine overhaul and I'd like to add horsepower.  Could I just put in 175 pistions and get a 10 hp boost?  Or is there more to it?  What would be other reasonable ways to add horsepower in an overhaul?
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2011 at 8:01am
the 175 pistons do have a higher compression ratio which will help, also the 175 had a different camshaft and governor weights and spring which made more horsepower.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2011 at 10:53am
Higher compression, and a different camshaft AND a different larger carburator......governor control raises rpm rated to 1800 instead of 1650.
This page was generated in 0.062 seconds.
