Allis 180 parts
Al in WMA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Al in WMA Quote  Post ReplyReply Direct Link To This Post Topic: Allis 180 parts
    Posted: 23 Aug 2011 at 8:34pm
I'm looking for the left sway block for my 180.  Are these still available new?  I'd be happy with used...  Could use a factory top link too.  Thanks
Education is what you get when you don't get what you wanted.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2011 at 9:50pm
Not available new since AC is no longer around to cast them.  They can be found used as many different models used the same ones.  Same for the top link - good luck finding one though...
nsula_country View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nsula_country Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2011 at 10:36pm
I bought a new RH sway block for my 180 recently. I believe it was an A&I product from, I believe "Walt's Tractors" website (not advertising the site). I know I ordered several parts from them like some gauges, ect.
I'd check dealers for A&I products for the part. Seems like only one side was available though... Could be wrong. They are out there after market.
CT
2014 LS P7010C, 1962 Farmall 504 Diesel (1st tractor) w/ 2008 Koyker 220 FEL, 1968 Allis Chalmers 180 Diesel, Komatsu PC38UU-2 Excavator, Various attachments for all!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2011 at 11:15pm
Yes - left & right Cat TWO sway blocks are available from any A&I dealer after market.  Also very easy to come by used as D17 SIV/170/175/180/185/190 all used the same sway blocks.  Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2011 at 4:52am
Mike...you forgot one. The D19 is also the same as the ones you mentioned. I recently bought a nice original set off E-Bay. However,I do happen to have (1) left side sway block that's extra that I really don't need at this time that I would sell if interested,Al. E-mail me at rickinmo@socket.net,if interested.  Rick
Post Options Post Options   Thanks (0) Thanks(0)   Quote nsula_country Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2011 at 8:21am
Are there Cat ONE blocks for a 180? I assumed you would just remove the blocks to make it Cat ONE? Am I wrong?
CT
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2011 at 8:31am
No - there are Cat ONE blocks  that AC made that you bolt on in place of the Cat TWO blocks.  They are EXTREMELY hard to find and nobody makes them aftermarket.  Some people make their own out of wood.  This has been discussed on here before.  Mike
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
This page was generated in 0.127 seconds.
