wd pto gear box
Terry GA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Terry GA Quote  Post ReplyReply Direct Link To This Post Topic: wd pto gear box
    Posted: 23 Aug 2011 at 2:21pm
Hi all,wondering if anyone has ever swapped gears from a cracked pto gearbox housing and put them into a new housing?If so how hard is it what should I need to do it.Thanks
Terry.
I couldn't repair your brakes, so I made your horn louder.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2011 at 5:10pm
It's very easy. you will need a Seal and gasket. when you slide the shaft out of the gear two balls and a spring will come out. When you put back together make sure the shifting fork is in the groove or you'll be taking it back apart.
