Sealing Hydraulic Leak
JCSinPITTS,PA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JCSinPITTS,PA Quote  Post ReplyReply Direct Link To This Post Topic: Sealing Hydraulic Leak
    Posted: 23 Aug 2011 at 7:09am
I never use the coupling under the seat and it leaks everytime I use the system, I played with the ball inside and jiggled it around and sprayed brake cleaner in there hoping some dirt was under it but no luck. So I deciced to cap it off and bought a cap and screwed it on but it leaked, so i added some permatex and it leaks, so i added some cork and rubber inner tube and it leaks, how do i seal this off since i dont plan on using it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2011 at 7:22am
Take it off and cap the line or replace the coupling with a new one. There is no way of sealing a leak with 3500 psi on the back side without correcting the original problem.
stray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stray Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2011 at 8:50pm
If you aren't going to use the coupler I would take it off and get a Hydraulic pipe cap and use thread sealant on it not teflon tape.
1969 190XT series 3
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2011 at 9:23pm
Put red loctite on threads screw cap on let it set over night.    MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2011 at 10:45pm
If it is a female coupling , put a male coupling into it with a cap/plug in it and it should be sealed. as long as the O ring is good no leak should be there .
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2011 at 5:41am
Is the nipple coming out of the valve cracked?
Wink
I am a Russian Bot
