H3 Gas gauge
largeonee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote largeonee Quote  Post ReplyReply Direct Link To This Post Topic: H3 Gas gauge
    Posted: 22 Aug 2011 at 9:20pm
Hi  Has anyone dismantled the  fuel gauge for an H3?  mine is in good shape  but there appears to be something behind the dial that is stripped.  It looks like the ring around the lens should come out. But how do I get it out without destroying it?  On a good note I have it running  and moved it back and forth about ten feet yesterday.  I am also missing the breather cap for the hydraulic and shuttle clutch.  The part it goes on looks like a miniature radiator neck.  any ideas on where to get one or what I can use in its place
thanks
Jeff in the UP
Kipn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kipn Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2011 at 1:22pm
I took mine apert cause the glass was cracked. Don't think that I will be able to put it back together without it leaking. The chrome ring has to be pried/cut off.
1961 H3
This page was generated in 0.199 seconds.
