d17 engine update |
Post Reply ![]() |
vyvyjim ![]() Bronze Level ![]() ![]() Joined: 11 Sep 2010 Location: WAUKESHA, WI Points: 146 |
![]() ![]() ![]() ![]() ![]() Posted: 21 Aug 2011 at 1:20pm |
I asked about replacing my series IV d17 "knocking" gas engine with a 262 gas and the consensus was to keep the present engine. However, if I'm going to overhaul it what can I do to increase the horsepower?
mlpankey ![]() Orange Level ![]() Joined: 13 Sep 2009 Location: Vols country Points: 4580 |
as much as your pocket book or wife will let you.
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21987 |
Overhaul would include new pistons, sleeves and rings. Get an OEM AGCO set from a 170 or 175 which is the same bore and higher compression and will not be hard on gasoline use as compared to overbore kits.
Post Reply ![]() |
