Snowblower for D14
wkburns View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkburns Quote  Post ReplyReply Direct Link To This Post Topic: Snowblower for D14
    Posted: 21 Aug 2011 at 12:13am
Hello, I am new to the forum. Looks like an interesting forum. I am located in south central ND.
I bought a D14 last winter to move snow around my farmyard. I have come to like the tractor a lot and thought about getting a snowblower for it. I don't know anything about what size or type it can handle. Any help would be appreciated.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2011 at 9:48am
I would not go larger than a 6' 3 point hitch model.  You can use the hand clutch to inch it back in heavier snow.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkburns Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2011 at 10:39pm
Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2011 at 9:41am
If doing a lot of snowblowing, consider swapping the rear tires <--->. That way you'll get better traction as tires are 'pointing' the correct way,though if you get stuck......
