Zenith carb help
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Topic: Zenith carb help
    Posted: 20 Aug 2011 at 12:36pm
Anybody have an idea what the proper float heigth should be for a 9 00 12522?
I believe this is a universal replacement carb, and the rebuild instructions don't address specs for it. Instructions give settings for series 61, 62, 67, 68, 161, 267, 63, 63M, 263M, but I do not know which this carb is equivalent to. I was just going to pick one and try it, but there is quite a span in the numbers
I am still confident of this;
Wait for the Lord;
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2011 at 12:45pm
Lou, There may be info in this that could help you.
Go to page 15 for the start of the Zenith section.
http://l-36.com/carb.pdf
I Love Meatballs and Dumplings on Toast with Gravy and Rosemary and ??? {Open For Suggestions}
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2011 at 1:29pm
Turn it upside down and make sure the floats are parallel with the base and it will be close enough. I have not measured one in years.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2011 at 1:32pm
Thanks guys! Dick, after perusing over the site Jeff posted, I noted the specs for tolerance were pretty wide! I think I have a game plan now. Back to the "shop"
Wait for the Lord;
