Quick crash course in Carb adjustment
Freighttrain View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Freighttrain Quote  Post ReplyReply Direct Link To This Post Topic: Quick crash course in Carb adjustment
    Posted: 15 Aug 2011 at 9:33pm
Give me a quick crash course on how to adjust a Marvel Schebler.Just took mine apart,cleaned,replaced the gaskets,Idle needle,Float needle and seat.How do I set the valve on the bottom?The idle is pretty easy.Turn till it sputters then back off a little till it runs good.Atleast that is how I was told.But the bottom one I don't know about.Gotta figure out how to fix the throttle screw.Some numb nuts screwed it in all the way and jammed it and the spring tight.The stop was missing and I made a new one out of a roll pin.Now the butter fly doesn't close all the way.
Jim Hancock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Hancock Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2011 at 11:04am
Hi FT.
The bottom screw is the load screw. You adjust it with the throttle wide open from what I had been told a many moon ago. If I'm mistaken, I can be corrected, but I don't think that I'm wrong. The needle screw is for the gas mixture when a load hits the engine. Think of it as the high speed adjustment. Screw it in to bottom and back it out about 2 turns and go from there on wide open. Shouldn't be off much. HTH. Have a good week.
This page was generated in 0.422 seconds.
