WD45 Cement pull wheel stand.
roughstock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote roughstock Quote  Post ReplyReply Direct Link To This Post Topic: WD45 Cement pull wheel stand.
    Posted: 11 Aug 2011 at 9:22pm
This picture was taken at the Newaygo County Fair's cement pull. I didn't get a chance to talk to this gentleman much so I cant remember his name. He put on quite the show in the 6000lbs limited class. The winner of the class was a D17 driven by Andrew Cox. I didn't get any exciting pictures of him. This fella ended up making the pull.
jhid View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jhid Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2011 at 9:30pm
that would have been a fun pull to see
red and green are nice for christmas, but orange is all year round
http://www.canadianantiquetractor.com/tractorforum/
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2011 at 9:46pm
Never seen anything like that.  Can you explain how the pulls work?  Looks like a can or two of courage and a death wish are requirements.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2011 at 9:59pm
Why would anyone want to see a tractor get that close to turning over? I have saw 2 pulling tractors turn over (not something I ever want to see again). One person spent months in hospital and never had good health ever after. The other died under the tractor. Both brought about better safty equipment. The people that pull these tractors without safty equipment don't use good judgement.
   Sat. night I blew the engine on my pulling tractor. Thanks for safty equipment(fire suit, full face helmet,engine shields and other equipment) I was not burned from a flash fire from oil. I felt the heat from the fire as it came past me, but wasn't burned.
   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote roughstock Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2011 at 9:59pm
How it works is, there is a steel sled that sits on a concrete slab. One each end of the sled there is approximately 6 feet of cable to hook up with. Each tractor takes a turn to pull the sled. A full pull is some where around 25 feet. The next tractor hooks up and pulls in the opposite direction. After all tractors have pulled the sled, more concrete blocks are added to the sled. Then time for the next round.
Post Options Post Options   Thanks (0) Thanks(0)   Quote roughstock Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2011 at 10:02pm
Mack, the fence is blocking it, but he is sitting on his safety bars. I think he needs to lower them a bit.
Brian
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2011 at 10:07pm
I got a -45 about that high one time by accident, pulling a junk car up out of the woods and it snagged on something............scared the bejeepers out of me!
I am still confident of this;
Wait for the Lord;
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2011 at 10:13pm
I want to know how many broken front spindles he has replaced?  Coming down from that easy like, is not a simple task...
Still in use:
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2011 at 9:07am
You should see the oil pressure drop when it gets in that position.
I have a few log roads my Dad used with horses so steep that you can see the oil pressure drop off if I try to travel them with the WD.
Over the years, I've constructed a few new roads less steep.
That is one impressive picture, tho!!
Burgie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2011 at 9:19am
Your hitch point sure gets a lot lower when your front end is that high in the air.
"Burgie"
