Injector Pump Parts
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Topic: Injector Pump Parts
    Posted: 11 Aug 2011 at 6:23pm
After studying the Service Manual for the Allis Chalmers Fuel Injection Pumps and much online research, I have just about decided to rebuild the Roosa Master DBGFC637-54AF injector pump for my 180 myself.
Called around for exchange pumps and to re-builders for pricing.  Exchange pumps from $700 and up to over $1,000.  Depending upon the problem with the pump, rebuild from $300 to  $1,200.
Two things I know my pump will need is the flex ring and the pilot tube. Also a seal kit.
The last time I was inside an injection pump was when I was in college in the mid '70s.
My next problem is a good, reliable and reasonably prices parts supplier.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2011 at 7:44pm
I was told that 30 bucks is all it costs in parts to rebuild an injector pump on a 180 ; dont know how true it is ?  I called a pump shop on a rebuilt one while back and it was $1000 ; I asked why , everyone else was $450-500 ; he said they are RARE ; interesting selling point i guess but WRONG ANSWER ; Andrew Gubbels does a good job and VERY resonable
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2011 at 1:00am
IT   IS   ALIVE!!!
At 5 minutes after midnight, I started my 180 diesel.  Poor old girl had a bad flex ring and it took me a while to get around to fixing her.
With the help of a rebuild manual, parts kit and a couple of conversations with a couple of pump technicians I rebuilt the pump myself.  The last time I saw the inside of an injector pump was when I was a freshman in college.
The pilot tube had a groove so it got replaced.  The pump vanes need to be replaced but that will have to wait until I obtain a new set.   The flex ring was shot and was replaced.  Measured the rollers and met the specs.  Also replaced the check valve.
With shipping, I have $100 invested in the pump.
Jim Hancock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Hancock Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2011 at 1:10am
Sounds like there might be a sideline business in the making! Way to go on getting your pump repaired.
I was also in college in the mid seventies and it would take me awhile to refresh my memory on rebuilding those things.
Have a good one Clay.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2011 at 6:25am
Glad to hear you got it together. I know my D17D needs the flex ring too. Same scenario, last time I did one was in trade school. So far I haven't gotten the courage to do it...
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2011 at 8:10am
One thing I did, which no one suggested, was to take pictures.
These pictures were taken at several angles.  This made it easy to know which fuel line went where.
JPG AUSTRALIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JPG AUSTRALIA Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2011 at 8:14am
whats the rebuild manual called? just wondering because there used to be a few on ebay.
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2011 at 9:16am
Service Manual for the Allis-Chalmers Fuel Injection Pumps      Roosa Master D & DB   Bosch PSB.    I bought this manual on Ebay.   Make sure you are buying a service manual and not a parts manual.
The 180 pump is a DBGFC637-54AF.
Roller to Roller Setting 1.951" +/- .0005
