WD rear hydraulic problem
G226WD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote G226WD Quote  Post ReplyReply Direct Link To This Post Topic: WD rear hydraulic problem
    Posted: 01 Aug 2011 at 6:49pm
Im starting to notice something lately whenever i pull with the drawbar on the allis 3pt hitch if i pull hard the hydraulics always lifts high as it will go and sometimes it will stay up even when i move the left lever on the quadrant is all the way to the bottom.
i have to shut the tractor off sometimes to get it to go down.
i made a homemade box to carry my chains in on the 3pt hitch but the box keeps getting smashed. is there something wrong or is it a setting somewhere
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2011 at 6:59pm
Sounds like you need to set your hyd pump to the hold position.  Should be able to use the sticker on your battery box, or this picture.
AaronSEIA
This page was generated in 0.052 seconds.
