220 rearend problem
Mike NEIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike NEIN Quote  Post ReplyReply Direct Link To This Post Topic: 220 rearend problem
    Posted: 31 Jul 2011 at 9:27pm
Dad was plowing today and got to the end raised the plow and it was just like having a diff lock engaged and wont release. Any ideas and how big of a job will it be to fix? thanks
                                       Mike
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2011 at 9:28pm
Big job.
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2011 at 9:58pm
Mine did that a few years ago.  Got it to release turning back and forth and hitting the brakes.  Still going, mechanic said don't worry about it unless it keeps doing it.
ranger42 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ranger42 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2011 at 7:21am
You don't seem to hear much about 210/220 rearend problems....what that a fairly rare occurrence?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike NEIN Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2011 at 6:32pm
The only rearends I've ever heard of going bad is early 190's. I tried for an hour this morning to get it to let go or something but it's still hung up.no noise or anything it just wont turn.
farmtoybuilder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmtoybuilder Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2011 at 7:12pm
Ouch! You might try jacking one side up and try turning -pulling that wheel backwards?  Was it run low on oil? As Dr. said its a big job and could be expensive.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike NEIN Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2011 at 11:32pm
Farmtoybuilder,the wheels turn ,I've been driving it around the shop trying to get it to break loose but it's like kicking the diff lock pedal the front tires just slide when you try to turn. Maybe the seven bottom had something to do with it, who knows.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2011 at 1:27am
Was the land wheel spinning alot before this happened?  Mine was.  Made a screeching noise trying to turn until it broke free.  Also try in reverse.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2011 at 5:52am
Spinning will take out the differential. When I was at Peterson Implement back in the early 80's they all said they never had any rear end problems with any 210 or 220 they sold except for a new one that had a pin hole (bad cast) in the rear main casting which they replaced of course because it leaked oil.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2011 at 6:45am
To prevent differential failures it is imperative to have the oil level in the hydraulic/transmission compartment FULL of oil and even an inch (5 extra gallons? on a 220) overfull would be better in an attempt to submerge the differential in oil. It is also equally important to have enough weight (fluid/cast iron/dual wheel or all three) on the land wheel to keep the slippage to a minimum. A properly operating Traction Booster is also a good thing along with a land wheel tire that has good tread on it and no more than 135 rated HP.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2011 at 7:32am
Peterson Implement was adamant about not turning up horse power. In fact they would encourage 7080 owners to derate to 7060 specs back in the 80's. Not because of rear end failures but cause of the high output 426 problems. Even on old 45's and 17's they would discourage owners from going to upgrade kits like a 17 kit into a 45 etc.
Wink
I am a Russian Bot
Jim NEIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim NEIN Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2011 at 5:09pm
It's on land plow, 4 new tires on rear, no fluid but inside cast weights.Thanks
