d17 alternator |
Post Reply ![]() |
vyvyjim ![]() Bronze Level ![]() ![]() Joined: 11 Sep 2010 Location: WAUKESHA, WI Points: 146 |
![]() ![]() ![]() ![]() ![]() Posted: 30 Jul 2011 at 4:16pm |
I'm having charging problems on my series IV D17.
Should I see if I can get the generator fixed or put an alternator on? If the answer is an alternator, which one and does the positive ground system make a difference as to the alternator?
CTuckerNWIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
If your wiring is up to par, the simplest thing to do would be repair the generator. Many times a good cleaning and replacing the brushes and maybe a bearing and it's good as new.
Bill Deppe/AC Salvag ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Maquoketa, Iowa Points: 974 |
From experience, the new regulators aren't the quality they used to be. My local generator repair shop worked with me and we've developed a transisor and diode setup and mounted it into the original regulator. This has really worked great so far, smoother regulator control and still looks original
Jeff Z. NY ![]() Orange Level ![]() Joined: 11 Sep 2009 Points: 7326 |
Yes the ground does make a difference. If you don't want to switch to - ground you can get a + ground alternator.
DSeries4 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7516 |
I vote for fixing the generator.
Post Reply ![]() |
