Choke rod location for WC speed patrol
Farrell(Utah) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Farrell(Utah) Quote  Post ReplyReply Direct Link To This Post Topic: Choke rod location for WC speed patrol
    Posted: 25 Jul 2011 at 5:57pm
   Currently, I am restoring a 1941 WC speed patrol.  For the life of me, I can't figure out what the choke pull rod looks like and its location.  Mine must not have had one when it was disassembled for sand blasting.  Can someone send a picture of the rod, its location, and where it mounts on the steering column?  The tank cradle does not have the hole for the cross-rod like the WD and WD45 have for the choke assembly.  Thanks.
A(1937), 2 G, 2 WD45 diesels, 6 WD45 gas, UC, 2 WD, D17 gas, WF, Farmall 400, D12, Kubota B3030
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2011 at 7:53pm
On my Speed Patrol it uses the pivot rod thru the tank support but mine is a 1949. I assume yours has a bolt on front end?  Mine also has a second rod for the kill on the mag. I'm not at home this week so I can't send you a pic.
This page was generated in 0.229 seconds.
