7G A
doctorcorey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote doctorcorey Quote  Post ReplyReply Direct Link To This Post Topic: 7G A
    Posted: 25 Jul 2011 at 9:59am
 Hello again, I need a couple of bits of info from 7G (A) owners. One, I'd like to know if this loader had bolt- on or weld- on front skid plate, that is, the one under the radiator. Mine is welded on, and makes it nearly  impossible to get to the shovel hydraulic pump lines. Will radiator removal help? Next, I'd like to know common part no.s for the fan belts. Mine has timing cover gear driven belt drive pulley with the sliding bar adjuster. I bought this loader last week, it sat for years, and after changing fluids and filters, it fired up and purred like a kitten.
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2011 at 12:27pm
Yes the front short pan is weld on frame and the 2 belt fan drive # should be 4349777
Post Options Post Options   Thanks (0) Thanks(0)   Quote doctorcorey Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2011 at 1:29pm
 That's good info, gemdozer. So what to do to remove pump, pull radiator? I just need to change the pressure hose, but I can only one hand it (and I've got long arms) and those 3/4 head bolts are smoking tight! Maybe I can drill an access hole in the side of the front nose and get a long extension and a wobble on it. Do you know the commercial part number (Napa, Car quest, etc.) for those belts? Thanks again, Corey
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2011 at 4:40pm
the hd7 nose should have 2 bolts each side  and lift the loader  and make security block and remove the small bolt each side nose and lose the big one with a 3/4 ratchet and pull the top nose in front and you should have some room for remove your bolts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote doctorcorey Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2011 at 10:10am
Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote doctorcorey Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2011 at 1:28pm
  I'll update you guys as I feel it is polite to give some of these stories an ending. Once I got my main pressure line to front pump changed and replaced a few other pop up leaks, I cleaned out the injector pump circuits and drained about 20 gallons of black fuel out of the tank. Changed filters, removed all drain plugs in the trans, oil pan, final drives, etc. to check for water (there was plenty) and topped off the fluids to test. Installed two hot batteries and hit the starter button about a hundred times and finally got that old starter to hit. Cranked the engine for about 10 second and then suddenly that old 7000 just sprang to life and sat there and shook for a few seconds,  and then purred like a kitten. Oil pressure good. Pulled shovel handles and up went the boom! I felt like a superhero with a new toy.                                          At any rate, after a couple of weekends of fiddling and adjusting, I was able to drive it and everything works good. I'm now able to knock down trees and move most anything I please. This loader had sat outside for 8-9 years uncovered. So my total investment is around 5,000$ and I'm gonna paint it as soon as I can choose the right shade of yellow. Thanks for all your help. Corey in KC
Edited by doctorcorey - 18 Oct 2011 at 1:38pm
michale34 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michale34 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2011 at 8:15am
that a good looking machine  thats my most  favorite machine ac built. thats the first time I have ever seen the air breather like that on a 7g usualy its in the dash.
Dozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2011 at 4:58pm
could you post a picture of the air cleaner? The aircleaner on my 7G is in the dash.
Mactractor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mactractor Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2011 at 9:30pm
got a  real good loader there by the look of the pics Doc. Sprockets look new, which signals good track chains. Belts we use down here are Gates 20A 1295, or Dayco 74349715 42-0399  if thats any help to ya. Wish I could find a 7G like that down here.
Cheers  Mac
Post Options Post Options   Thanks (0) Thanks(0)   Quote doctorcorey Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2011 at 9:10am
this is the best pic I can provide until monday. I'll get a close up on Sat. C.
Edited by doctorcorey - 20 Oct 2011 at 9:13am
Post Options Post Options   Thanks (0) Thanks(0)   Quote doctorcorey Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2011 at 9:14am
Post Options Post Options   Thanks (0) Thanks(0)   Quote michale34 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2011 at 9:45am
i do remember seeing a 7g one time with the throttle leaver in the floor instead of on the dash and by just getting a glempse of this machine it looks like the bucket controles are like the  6g
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2011 at 5:30pm
Thank you for the picture. I find it interesting that your HD7 is different than mine. My s/n is HD7G 23776. Is yours newer or older than mine?
Post Options Post Options   Thanks (0) Thanks(0)   Quote doctorcorey Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2011 at 5:53pm
  Mine, I think was made in 1961. I'll check the number tonight and let you know the number. I can tell there was some mod made to the throttle linkage. They eliminated the speed governor linkage from the tranny. I have a  lever throttle at my left foot. I'll say one thing, they built every part of these machines out of plenty of iron.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2011 at 9:24pm
get a guard for the radiator before you do to much work with it , somethiing sturdy even if it isnt correct , a good heavy expanded metal grid or even some walk decking material and welded to frame . radiators are expensive to replace when a branch or something pokes through the core .
HD6 Merv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6 Merv Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2011 at 11:55pm
Hi Doc
Alot of people disconnected the ground speed governor from the throttle; and just left the throttle wide open and used the decelerator to control ground speed; like most other crawlers. Later machines did not have ground speed governor, or the push start pump. Certainly does away with alot of excess needless plumbing. My 6ep also had it all removed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote michale34 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2011 at 8:13am
i know one thing that the parts book and service manuals all shoe the 7g having the front radiator guard looking like the 6g with the round holes and 2 eyes but everyone I have seeen looks like a straight grill.
Post Options Post Options   Thanks (0) Thanks(0)   Quote doctorcorey Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2011 at 9:25am
  Ser. Number 22970. Not too far apart....
Post Options Post Options   Thanks (0) Thanks(0)   Quote doctorcorey Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2011 at 9:28am
  I have the tube grill installed now, but the tractor came with a bunch of sheet metal (plate) parts, some of which I don't think fit this tractor. I have a twenty year old reciept for a radiator rebuild on this tractor and the price was 1400$!!!!. Hard to believe. In the bottom of one of my pics you can just see the mounting tab on a heavy plate radiator guard, the holey type.
Post Options Post Options   Thanks (0) Thanks(0)   Quote michale34 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2011 at 10:53am
i see that guard thats how all 7gs i have seen looked with that type of guard my dad was a ac man bought 2 6g s brand new ,he bought a 7gb one time and didnt like the pedal steering and I aways wanted a hd7g but he always hd 6gs  one of these day I hope to get a 7g
Post Options Post Options   Thanks (0) Thanks(0)   Quote doctorcorey Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2011 at 2:33pm
I didn't know I already had this picture:
Post Options Post Options   Thanks (0) Thanks(0)   Quote michale34 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2011 at 3:37pm
ok it looks like the air breather was in the das and was taken out and replaced by the round one
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2011 at 5:46pm
My Fiat-Allis parts book shows the round type air cleaner as the "First Type". The dash mounted air cleaner was effective with s/n 23003 I had thought that all HD7G's had the dash mount.
Tad Wicks View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tad Wicks Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2011 at 7:11pm
DC in KC, I don't know what to say about paint these days, when I painted my 11, I pondered on acrylic enamel, poly paints, and just regular enamel. I really do regret my decision to go with Tisco brand synthetic enamel and hardener, it is going away fast and the color didn't last a year before it started fading and the hood and top of the tank are almost yellow now after several years of California sun, but, to paint with Poly-urethane was going to be well over the $1000 mark, so you spend it on paint or you spend it on re-paint. It kinda reminds me of saying they had on the farm when I was growing up "There is never time or money to do it right, but there is plenty of time and money to do it over"(insert smiley face here). Tad
