Firing order for a CA |
| Author | ||
Doyle B(NY)
Topic: Firing order for a CAPosted: 24 Jul 2011 at 5:41pm |
Hi just wondering if any one could get me the firing order on a CA , Thanks.
| Sponsored Links | ||
RyanTN
Joined: 12 Sep 2009 Location: Stewart Co, TN Points: 415 |
Posted: 24 Jul 2011 at 5:48pm |
1-2-4-3
RyanTN
Posted: 24 Jul 2011 at 5:49pm |
...and one is closest to the radiator...
Doyle B(NY)
Posted: 24 Jul 2011 at 5:54pm |
Yes thank you very much.
Dick L
Joined: 12 Sep 2009 Location: Edon Ohio Points: 5093 |
Posted: 24 Jul 2011 at 6:26pm |
If you ever get caught without someone to ask what a firing order is you can always remove the valve cover and watch the rocker arms. When both valves to a cylinder are closed it needs to fire. Making sure the rotor points to a wire terminal and that wire goes to that cylinder with that piston at top dead center.
wkpoor
Joined: 25 Apr 2010 Location: Amanda, OH Points: 825 |
Posted: 24 Jul 2011 at 8:47pm |
Maybe easier yet just take out all the plugs and check with your thumb which cylinder are on compression stroke as someone else slowly cranks.
1955CA
Joined: 10 Sep 2018 Location: Ontario, Canada Points: 602 |
Posted: 14 Jun 2024 at 10:05am |
Just curious. Everyone says the cylinders are from radiator back 1-2-3-4.
Just wondering why there a big 2 stamped in the block under what you say would be #3 cylinder?
Lon(MN)
Joined: 11 Sep 2009 Location: Merrill Wi Points: 2041 |
Posted: 15 Jun 2024 at 6:51am |
I haven't seen any recent Dick L posts. ????
http://lonsallischalmers.com
Jim.ME
Posted: 15 Jun 2024 at 6:58am |
Is the 2 stamped or cast into the block? I am guessing it is cast in. Numbers cast into parts often do not mean anything to anyone outside of the foundry. Some are date codes, pattern changes, etc. In this case I would say the 2 is a foundry mark with no relation to the cylinder it is near.
1955CA
Posted: 15 Jun 2024 at 7:03am |
Okay, yes cast in. I thought maybe the number 2 meant the cylinder number just as many of my old Ford engines had the cylinder numbers cast in. Both my CA's have this big #2 cast in the block. |
Jim.ME
I think he and his wife are still having health issues. It has been a couple months since he posted on YT. He said he was going to be having cataract surgery soon after that post.
