Need Alice B engine parts in Colorado
ihscout View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ihscout Quote  Post ReplyReply Direct Link To This Post Topic: Need Alice B engine parts in Colorado
    Posted: 24 Jul 2011 at 1:23am
Hi all. Last week I had a SN vin year ? and thanks to A-C (unofficial) members we figured it to be a 1940. Someone gave it to me and every thing is there. Has a hydra loader. It hasn't run for a couple years. Prior owner left the exhaust flap off  the vertical  riser. Of course, internal engine saturated, seezed, bent push rod and valve etc. Anyway, I pulled the oil pan and it has minimal oxidation on lower end components. I think the water sitting on pistons in the cyl. some how bled by rings and rusted them to cyl. wall?  I have filled the entire block w/ oil and also have the oil sitting on top of pistons. Looks like I'll keep. fix and use my little B, Why would you think the p-rod and valve bent? So, I'm tearing down the motor and fixing.  Would welcome any info on best place to shop for parts.
MilesGray (CO/KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MilesGray (CO/KS) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2011 at 1:40am
Welcome to the forum! This is the greatest place to find information and knowledge on AC tractors there is! what I have found that works for releasing stuck pistons is 50/50 ATF/Acetone mix. Just sent you a PM.
Miles
Miles Gray (CO/KS)
5 1938 B's, 1940 B, 1944 WF C, 1948 NF C, Gleaner A, White Top Rotobaler, 1957 IH Golden Jubilee... I'm either a collector, or crazy!
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2011 at 7:31am
Maybe the parts got bent at some point if someone tried to pull the tractor and drop the clutch to break the engine free. Just a guess.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ihscout Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2011 at 8:21am
Do you think it possible, that if I can un-stuck the lower end, maybe could get by with only replacing one p-rod and one valve? Baring, the rest of p-rods are really straight?
Miles, I notice you have CO/Ks as your local. What part of KS?
Oh ya, the guy I got B from said he tried to pull start a couple years ago. Oh well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2011 at 8:55am
Once it's busted loose you should be able to check all the parts over and just replace what you need. Should be able to find plenty of used B parts from guys on here.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MilesGray (CO/KS) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2011 at 9:01am
Caldwell/South Haven... South of Wichita
Miles Gray (CO/KS)
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2011 at 10:05am
Alice Parts????
I don't think we should go there. LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote ihscout Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2011 at 12:21am
OK, not Alice, Allis. I'd never go there with Alice never, ever!
