5040 Brochure Pictures.
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Topic: 5040 Brochure Pictures.
    Posted: 22 Jul 2011 at 9:41pm
Found these in one of my google search's.
Edited by R.W - 23 Jul 2011 at 7:36am
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisChalmers37 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2011 at 12:33am
I believe AC had some of the best looking literature out there and this is proof.
Cal View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cal Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2011 at 6:35am
That was  the first 5040 literature. The very first tractors had 6 speed trans. not shown in any literature, they were tough little tractors, but you had to show the customer how to shift the 6 speed properly or you would be back taking the cover off and aligning the shift rails. Cal in Ct
ky wonder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ky wonder Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2011 at 1:00pm
i have its bigger green cousin , oliver 1355, and we have had it for 41 years, it has been an excellant little tractor that has served well with over 10000 hours on the original motor.
the little tractor has had a one clutch replacement and one set of thrust bearing and bushing in the front and that has been it.
i know they are not reak allis chalmers/olivers but the one i have has been a great tractor, even if fiat did build it
i like old tractors of all colors
Auntwayne View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Auntwayne Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2011 at 8:19pm
     I was lucky enough to be the only guy with tractor/ farming experience working at a tree farm when the 5040 came out. The nursery bought 2 diesels for the wagons and maintenance work. I have never forgotten the time I was brush hogging around the poly houses, and, a rock flew into the dash (look at lit.) and ricocheted into my eye. Out of all of the tractors I have mowed with, none, have ever had a dash design like that to make that happen again, until just now, my eye needs some visine bad !!!   I am going to copy the literature as its the first time I have ever seen it . Thanks for posting Richard
Post Options Post Options   Thanks (0) Thanks(0)   Quote Auntwayne Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2011 at 8:39pm
    I had to go back and read the literature, the FOOT THROTTLE was of little or no use on a tractor with that close of a wheel base.... wa waaaaaaa waa waaaaaaaaa wa waaaa, you know that was bad ,had to use hand throttle. DIFFERENTIAL LOCK, man was that ever handy, and, in a great spot. EASY OFFFRONT GRILL, you can say that again, it was always off under the front tires, I spent more time fiber glassing and painting the grills than farming !!!  Still love though, great little tractors !!!
