Dwell and timing on a WD
nowaktj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nowaktj Quote  Post ReplyReply Direct Link To This Post Topic: Dwell and timing on a WD
    Posted: 17 Jul 2011 at 7:48pm
Hi guys,
What is the dwell on a WD?  Also, how is this engine timed?
Thanks in advance,
Terry
D19D, D17D, WD, WC, Snobee, #83 Plow, SC Blade, 14' disk, 400 series planter, B , Terra Tiger, M Dozer w/Baker Blade, TL-12, 42S Grader, G
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2011 at 8:52pm
I'm not sure what the dwell is, but .020 works for point gap. There is a window in the side of the frame inline with the the rim of the flywheel. Center the FIRE line in the window with the engine at full throttle. I just set them by ear. I had a long time A-C mechanic tell me the timing is right when you close the throttle from full rpm quickly to idle and you get one loud backfire out the exhaust.
