used Red Kote, now have red gas??
tractorboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorboy Quote  Post ReplyReply Direct Link To This Post Topic: used Red Kote, now have red gas??
    Posted: 11 Jul 2011 at 2:31pm
I took the tank out of the 1960 f 100 beat on it with my fist , got a bunch of rust out,  let it air out 2 or 3 days. Then I treated it with 2 qts red kote, turned it slowly till I thought it was coated all over, then turned it once every 20 min.for about 3 hrs. Let dry in diffrent positions for three days, put it in the basement at night to keep out of the dew. It's all back together, but the gas in my clear in line filter is RED!! Is ths normal for first fill-up??? I don't want to mess up a brand new Holley I just bolted on. Thanks , Keith
farmtoybuilder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmtoybuilder Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2011 at 2:50pm
I hope you drained out the excess after turning it! And no, fuel shouldn't be red.
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2011 at 3:29pm
It must not have been dry yet.. Gas should not be red.. I would drain the tank and let it dry until you can no longer smell it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisChalmers37 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2011 at 4:25pm
I used Red Kote in the tank on my '37 WC but I didn't put gas in it for about 2 weeks while I was painting it.
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2011 at 4:26pm
Heres the directions in PDF
