7045 ?
XT in pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote XT in pa Quote  Post ReplyReply Direct Link To This Post Topic: 7045 ?
    Posted: 08 Jul 2011 at 2:23pm
i am new to the 7000 series i was brush hogging today and i noticed it was leakin diff fluid out around the pto and my stub shaft is loose now what caused this to happen and what will it take to fix it ?
 Thanks Shawn
190XT,D17and 7045
Russ-neia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Russ-neia Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2011 at 6:35pm
Need to drain oil, take cover off under PTO (slide drawbar out of way) and have a look.  The bearings are tapered with a stake-nut to put load on them, just like a wheel bearing.  Likely they are loose or failing - allowing shaft movement, which causes the seal to leak.
Make sure your bush-hog PTO telescopes freely under load.  I had a round baler ruin my tractor PTO because it had a tight spot in it.  It would telescope freely by hand but put torque to it and it wouldn't slide.  Took me and a mechanic several hours to finally figure that one out!
This page was generated in 0.036 seconds.
