D-14 seal issue
Me and My ACs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Me and My ACs Quote  Post ReplyReply Direct Link To This Post Topic: D-14 seal issue
    Posted: 06 Jul 2011 at 10:37am
Hello I am new here and have a question. My d14 is losing ALOT of hydraulic fluid into the transmission and power director compartments. I checked the ram and hydraulic lines under the back. So i pulled the inspection panel off for the power director and started the tractor up and she starts pumping hydraulic fluid throgh a hole that is between the main and pto shafts. i cannot tell if there is a bearing that needs a new seal in there or if it is just suppost to have a plug. thank you very much for any help.
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2011 at 12:13pm
Sounds like the plug came out of the end of the trans countershaft.  Its  a steel soft plug, above the pto  shaft.
This page was generated in 0.223 seconds.
