WF allis chalmers grader AUS
q4016lanz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote q4016lanz Quote  Post ReplyReply Direct Link To This Post Topic: WF allis chalmers grader AUS
    Posted: 05 Jul 2011 at 8:56pm
I got this old wf grader about 10 years ago 600 miles west of here for $200 i was out there on a job and had room on my truck so i hauled it home how many wf graders did they build this one has a Tutt-Bryant-Ltd tag the back end is broken i have another wf back end i have to remanufacture the steel offset plate for the right hand side one day. cheers john & brad
15 allis chalmers tractors
9 lanz bulldog tractors
2 water cooled deutz
9 john deeres tractors
14 Aus made orange chamberlains
I spent most of my money on old tractors I wasted the rest
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2011 at 9:56pm
Over here they are W Speed Patrols built on a WC chassis and they made 3751 from 1940-1950. Nice to have in the collection.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2011 at 10:01pm
The first 678 were built at the LaPorte plant 1940-1942, the rest were at the Spingfield plant from 1945-1950. None built in 1943 and 1944. Does yours have a serial # on the rearend or on a seperate tag on the front?
OrangeKiwi(NZ) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OrangeKiwi(NZ) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2011 at 10:18pm
John, you may have something unique there ? As has been said already, AC did produce a W Speed Patrol which was based on the styled WC tractor. Judging by the first photo in this post, your machine could have a WF rear end ? It's definitely got a WF clutch pedal and foot plate. Was the rear end stamped with a WF serial number ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote q4016lanz Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2011 at 10:33pm
The orignal broken rearend number is WF2962 and the tag on the side it has a number as well it will be the Tutt-Bruyant number hop this helps cheers john
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2011 at 7:15am
Never heard of a WF patrol-- save all the pieces as you may have a one of a kind unit there , as said it has a WF clutch pedal and rear end.
WC Dale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WC Dale Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2011 at 7:28am
The front axle appears that it may be narrower than the standard speed patrol as well. Interesting!
Post Options Post Options   Thanks (0) Thanks(0)   Quote q4016lanz Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2011 at 8:40am
Hi guys the front axle is a wf axle and theres WF tag on the of the grader the stering is the same as WF Tutt- Bryant Pty only made a few WF patrols there is a lot of WC patrols in AUS hope this helps
This page was generated in 0.402 seconds.
