I need D15 II clutch help |
captaindana
Joined: 14 Sep 2009 Location: Fort Plain, NY Points: 2573 |
Topic: I need D15 II clutch helpPosted: 05 Jul 2011 at 9:16am |
I need to know specs for the step on the D15 II flywheel. I am having it machined and need to know the difference from the outer bolt on area to the inner surface where the clutch works. Thanks y'all! Dana
Jeff Z. NY
Posted: 05 Jul 2011 at 9:27am |
The machine shop I use {NAPA} has the specs in their flywheel books.
If you shop doesn't have the specs they will measure from a spot on the flywheel that is not worn and adjust the lip to the new depth of the flywheel surface. |
captaindana
Posted: 05 Jul 2011 at 12:26pm |
Het Jeff thanks. My guy doesn't have the lip specs so I am trying to find them. OK gotta go bale bout 6 loads!
