AC 220 compared to other brands in 1970
WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Quote  Post ReplyReply Direct Link To This Post Topic: AC 220 compared to other brands in 1970
    Posted: 04 Jul 2011 at 9:45pm
Year is  1970 - performance comparison of AC220 to what the competion was building in the 1970.
eg  JD 4620. Does anyone have the Nebr. tests reports for these tractors.
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 8070 fwd, 716H and 1920H
ky wonder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ky wonder Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2011 at 9:55pm
you can check hear they have the easiest way to look them up
Edited by ky wonder - 04 Jul 2011 at 9:55pm
i like old tractors of all colors
Gatz in NE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2011 at 10:07pm
WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2011 at 10:10pm
Thanks
Anyone farm with these tractors when new to give a comparison report .
acd21man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd21man Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2011 at 10:48pm
we have a 220 great tractor
nsula_country View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nsula_country Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2011 at 11:03pm
Looks like the 220 would do the same work at 1/2 gal/hr of fuel less.
CT
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2011 at 11:24pm
220 complete test report
4620 complete test
220 Manual
    Max PTO HP at rated rpm - 135.95. Economy 15.66 HP Hrs/Gal
    Max drawbar HP at rated rpm - 117.21. Economy 13.54 HP Hrs/Gal
    426 cid turbo
    Bare weight 24.5x32 singles - 12,160#
    8 speeds forward 2 reverse
    Fuel tank - 51 gal
4620 SyncroRange Manual with syncronizers)
    Max PTO HP at rated rpm - 135.76. Economy 14.70 HP Hrs/Gal
    Max drawbar HP at rated rpm - 115.75. Economy 12.66 HP Hrs/Gal
    404 cid turbo
    Bare weight with 20.8x38 duals - 14,800#
    Fuel tank - 50 gal
Edited by Lonn - 04 Jul 2011 at 11:53pm
Wink
I am a Russian Bot
TexasAllis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TexasAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2011 at 7:00am
Looks fairly even on the PTO.  With ballast the 220 pretty much delivered the goods compared to the JD.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2011 at 7:16am
Notice the economy difference. The 220 will do more work on quite a bit less fuel. I couldn't find torque rise value but I'd put my money on the 220 to have better torque rise.
Wink
I am a Russian Bot
Kcgrain View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kcgrain Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2011 at 7:48am
The 4620 in real life was no comparison to a 220. Had one, been there done that kinda thing, 220 would eat a 5020, and would put the fear of god into a 6030.
427435 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2011 at 10:31am
The 220 from the factory would put out near it's Nebraska hp.  The Deere tractors of that era wouldn't come close.  If you increased the fuel to the Deere's to get Nebraska hp, your fuel economy really went into the dumpster and engine durability would suffer.
Mark
GTH-L Simplicity
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2011 at 11:06am
From what I can recall of our field demonstrations back then, there was nothing that came close to a Two-Twenty for field performance.  Heck, the One-Ninety XT diesels were outperforming IH 1206's.  Don't remember much JD competetion other than 4020's weren't close either.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ky wonder Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2011 at 3:30pm
the 4020 should not be close you are talking about a 92hp tractor
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2011 at 3:46pm
I think he was referring to when they demoed 190 XTs.
Wink
I am a Russian Bot
TerrySWIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TerrySWIA Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2011 at 6:22pm
I don' t have to read the Nebraska tets. I farm with these tractors everyday.  Ive got a 220, 4620, 1256, G708, 2150, 97, 2255. All FWA's, and there is none of them that have the power, the old 220 has. Every one of them have something I like about them. An employee of mine said it best. The rest of those tractors are OK, but none of them are fit to bring water to the old 220. The 4620 has been a very good machine but not much power.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2011 at 6:38pm
I always like the looks of the G708-------got any pictures??
Mark
GTH-L Simplicity
This page was generated in 0.095 seconds.
