2002 Chevy venture
WC7610 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WC7610 Quote  Post ReplyReply Direct Link To This Post Topic: 2002 Chevy venture
    Posted: 02 Jul 2011 at 11:16am
Hi
both front power windows quit.  From both driver and passenger switches.
1st thought was fuse and went thru the fuse box on passenger side dash-no luck
2nd thought was switches, but both sides wouldn't go bad at same time?
3rd thought was motors, but both sides wouldn't go bad at same time?
Any thoughts or directions appreciated.
Thanks
Gatordoc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatordoc Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2011 at 5:55am
Check for  broken wires in the rubber boot between the door and door post on the drivers side.
Dave A View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave A Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2011 at 8:21pm
drivers side switch is bad Rock auto sells the switches. Just been through this with 02 last year. now the one on the passager door has went out. If the window are rolled down in the rain they get wet and burn out
Play the game for more than you can afford to lose... only then will you learn the game.
Winston Churchill
woodbutch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote woodbutch Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2011 at 5:33pm
You might have 2 fuse  panels, my 03 pickup does. I know cause I finally read the instructions!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave A Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2011 at 9:38pm
emailed  you a wire drawing couldn't figer out how to put it in my message
Pull the drivers side switch out of the arm rest. Make sure you have power on the brown wires with the with the drivers side switch moving the window down
Edited by Dave A - 06 Jul 2011 at 9:41pm
Winston Churchill
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave A Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2011 at 9:40pm
one other thought make sure the black wire is grounded
Winston Churchill
This page was generated in 2.666 seconds.
