roosa master pump interchange
allis converted View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis converted Quote  Post ReplyReply Direct Link To This Post Topic: roosa master pump interchange
    Posted: 30 Jun 2011 at 10:36pm
If anybody can help I have a 190xt and need to know if a 200 injector pump will interchange. I found one that has been rebuilt for awhile but was never installed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2011 at 5:34am
Yes it will work. Set pump timing at whatever it should be for a 200 and there are two settings ?? 18 degrees BTDC and 24 degrees BTDC....numbers on the pump will determine which setting.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis converted Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2011 at 12:14pm
Thanks I will pick it up this weekend, do I need to turn it down or will it over fuel?
XT in pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote XT in pa Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2011 at 12:18pm
i have one on my XT from a 200 and the screw inside is turned in (down) all the way and it makes 126 on dyno
 Shawn
190XT,D17and 7045
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis converted Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2011 at 12:21pm
I hope mine can take it it seems a little weak I just got the power director problem fixed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote XT in pa Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2011 at 12:34pm
then maybe leave it at stock specs should be 93-106 somewhere around there if the cable is still through the screws.
         Shawn
190XT,D17and 7045
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis converted Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2011 at 2:16pm
I will check it out and see if it was turned up or left stock
This page was generated in 0.112 seconds.
