M2 wheat settings
fastallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fastallis Quote  Post ReplyReply Direct Link To This Post Topic: M2 wheat settings
    Posted: 30 Jun 2011 at 5:57pm
Can I run wheat with a bean screen? To help keep wheat heads out of the grain. Without running wheat out the back?
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2011 at 7:42pm
  YES YOU  CAN MANY COMBINES DID NO EVEN USE A SCREEN  HAVE BEEN AROUND COMBINES SINCE 1942   MANY THRESHERS DID NOT USE THEM EITHER  MY 2 CENTS
wheatbreeder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wheatbreeder Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2011 at 8:09pm
we run a f2 with the corn screens it works good just lay the screens flat for wheat 1/2 inch
Morley
Farm stuff 8050,6690,175,F2,5050,WD
HagerAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2011 at 10:51pm
Depends which type of chaffer you have.  In our F2 corn plus, we cannot run wheat through it as it will plug the tailings as it lets to all the chaff through.  We have a soybean screen, which is also used as a small grain chaffer which works very well in the combine for wheat and oats.  You would have to see if yours is the long or short tooth chaffer, and if it is squared or rounded ends.  You shouldn't have any problems with a soybean screen as it should be short round tooth chaffer.
ILGLEANER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2011 at 11:58am
The round tooth chaffer works the best. I had my square tooth in when I started on wheat with the L3, I took it out and put the round tooth in,you can clean the sample up with it, like Hager said,you get too much chaff coming through the square tooth,then you have to try to clean it with the bottom,and it runs to much over the return.
                                                  IG
