HD5G Batteries |
darrel in ND
Joined: 22 Nov 2009 Location: Hebron, ND Points: 8780 |
Topic: HD5G BatteriesPosted: 29 Jun 2011 at 8:08am |
I bought an HD5G at an auction Saturday, and hopefully a set of batteries will get it going. It has an alternator on it, so I would assume it is a 12 volt system, is that correct? And the alternator looks to be factory, again, is that correct? And last, since it has an alternator, that would make it a negative ground system, wouldn't it? It has no batteries in it now to use as a reference. Thanks, Darrel
q4016lanz
Joined: 23 Jun 2011 Location: australia QLD Points: 1442 |
Posted: 29 Jun 2011 at 8:27am |
Yes they are 12v and negative ground my hd5 starts on one big aussie 86 battery
gemdozer
Posted: 29 Jun 2011 at 12:56pm |
The HD5 should have a generator and yes it is 12 volt
dadsdozerhd5b
Joined: 27 Sep 2009 Location: lansdale pa. Points: 537 |
Posted: 29 Jun 2011 at 5:00pm |
since you question it's originality, somewhere on the alternator/generator should be stamped voltage and polarity. you can mess up a charging system with wrong polarity. starter does not care but alternator/generator does. one good size 12 volt battery should crank it well enough, that is all i use. good luck
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42274 |
Posted: 29 Jun 2011 at 8:00pm |
It came with two large 6V batteies , one in each side, hooked in series to give 12V pos ground . Came with a generator that had a double belt pulley and used a cut-out relay mounted on generator.
