New to me WD
1954f600 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1954f600 Quote  Post ReplyReply Direct Link To This Post Topic: New to me WD
    Posted: 29 Jun 2011 at 6:26am
Just bought a 52  wd. though the guy swears it is a wd 45. Havent researched it enough to find out for sure. Just curious what weight oil yall run in your tractors. I was thinkin bout rotella 15w-40. she doesnt smaoke one bit. its what i run in my 8n but that cause she burns alot and was trying to cut it back.  also was curious if the trans/hydralic/rearend uses all thesame oil like an 8n or are they seperate compartments. I havent made it up to TSC yet to get a manual. another Question is how do you operate the the single hydro outlet. Im guessing theres a valve that allows you to use the lever on the steering wheel that operates the lift.I grew up and have always been around deere but when i was little we had one wd 45 wide front. Kinda got a special place for them ole allis' ever since then. Any info you guys could offer would be great thanks
Matt
Tripp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tripp Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2011 at 7:30am
If it's a WD it will have a inspection plate on right side of the engine block behind the distributor. Wd45s have a solid cast block no inspection plates anywhere. In my 49' farm stock puller I run 15w40 just because of the high torque the engine has, as far as the hydrallics I run a 85 90 weight oil. Don't have a hydro outlet anymore so can't help there.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2011 at 7:54am
You can run normal motor oil in the engine. I use 10-30 but 15-40 is ok . the hyds call for 20W non detergant oil you can run unervsial hyd trans ( HYTrans)fluid in it. run the same in you hyd clutch. and either 80w90  or HYTrans in the trans. the rear hyd outlet works with your hyd lever on the steering wheel. when the lift arms get to the top  then what erer you have attached will lift. ifr you don't push the arms down they will stay up and you'll have pressure right away.
JohnCinMd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCinMd Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2011 at 9:25am
Welcome to the best Allis forum out there! When you get a chance, put up some pics of your WD. I've got my grandfather's 52 WD.
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2011 at 10:04am
Yes we need pictures!
acwdwcman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acwdwcman Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2011 at 12:21pm
pictures would be nice.. i also have a wd wide front.. good little tractors they are... i love mine. i used hydrolic/transmission fluid from tractor supply co. or rual king....as far a engine oil i think i use 15w-40 also..
wd with a freeman model 90 trip loader, wd45, 38 unstylled wc, b 10 garden tractor and 2-14 ac trip plow. grandpa has a 56 wd45. wd. allis chalmers snap coupler blade and 3 bottom snap coupler plow
