Cross reference oil seal
Ryan Renko View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Topic: Cross reference oil seal
    Posted: 27 Jun 2011 at 9:39pm
Can anyone help cross reference a oil seal for me?? I'm trying to save afew bucks by NOT going to Agco for it. The Agco part is #70229966. The old seal has 262FM124 C/R on it. Is the C/R stand for Chicago Rawhide? I've been searching and cant find this number. Thanks in advance, Ryan
kffischer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kffischer Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2011 at 11:36pm
do you happen to have dimensions too?  Was it a leather seal? Do you have earlier/later part numbers for it?  What's the application?
I've never seen 2 manufacturers' numbers on the same seal before but you could almost interpret the markings as CR# 262   and FM #124 or vice versa.  (CR is Chicago Rawhide and FM would be Federal Mogul.)
If I get a chance I'll check the catalogs at work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2011 at 11:40pm
Take the old seal to your local bearing supply house. They will find a replacement for you. If I had the shaft size and the bore it fits in, I could look it up in the books at the shop too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kffischer Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2011 at 11:53pm
I had more time tonight than I thought so I found it for you.
-Karl f
fme-cat.com (federal mogul/national seal online catalog, including interchange) says:
70229966 interchanges to National #472185
ations
Shaft Size (A)
1.75
Housing Bore (B)
2.623
Outer Diameter
2.627
Width (C)
0.312
Lip Material (D)
Nitrile
Series
470000
Type Illustration
47 *(double lip)
Rogers View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rogers Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2011 at 11:56pm
Here is a cross refferance page from Chicago Rawhide (SKF). Just enter the AGCO number and it will give you the C/R replacement.
Think for yourself and be your own expert. Be willing to change your mind; however, willingness to change your mind doesn’t mean that you will. Blindly following any path is the pinnacle of insanity.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2011 at 4:03am
Thanks for the help guys!!! I'll price it at Agco and then check the others and post the prices. Sometimes Agco shocks the heck out of you and sometimes you are surprised how reasonable they are.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2011 at 10:29am
Check section R of the Baum Hydraulics Catalog. No cross reference but a great list of seals towards the end of that section on page R29. Looks like by dimension and description a CR 17443 for $7.31 or a 17449 for $22.94. Date 2000 on top the page is their code for discount 20%. Once you've downloaded the catalog section you don't have to be on line to search by dimension or number.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2011 at 9:55pm
Agco wanted $15.00 for it and it would take several days to get it. Local parts store had a National seal for $7.50 and had it on hand. I bought a twelve pack with the difference and its all good now!! Ryan
