D17 IV Lift Arms Won't Lower
AllisUpstate View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisUpstate Quote  Post ReplyReply Direct Link To This Post Topic: D17 IV Lift Arms Won't Lower
    Posted: 26 Jun 2011 at 4:42pm
I know this is a common problem, and have searched and read the various posts regarding corrosion and hanging up of the Traction Booster and Position Control Linkages.  Everything is free, and with both levers forward, there is free play between the end of the piston coming out of the Traction Control and the metal tab connected to the linkages that pushes it in.
However, I can't get the lift arms to lower except if I use a 10 foot board as leverage to force them to lower.  A 3 bottom plow on the hitch will lower it straight off, so it is not that it won't lower at all, but it requires excessive force.
Is it possible that the "button" coming out of the Traction Control hydraulic body itself is sticking, and not releasing pressure?  I opened up the "rate of lower" little screw on the bottom of the valve to 2 turns, with no change.
Again, the linkages seem to be free, and there is free play between the piston coming out of the body and the steel tab that pushes it in, so it doesn't seem like it should be anything binding in the various linkages.
Just for background, the tractor has been used only intermittently by the PO, and has sat outside, but it not in terrible condition.  I went through everything with fresh fluids everywhere, and it has been running and working well.  It seems this hydraulic lowering problem is more recent, as it seemed to work ok a few weeks ago.
One thing I noticed is if I pull the Traction Control all the way back with a plow on it, with the main lever in detent, the plow will raise, then the pressure gauge will max out, and I hear the relief valve.  If I put the Traction Control forward, then move the Position Control full back, the pressure will go to about half max, like the manual says it should.
Any ideas?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2011 at 5:53pm
I'm assuming this is a SnapCoupler hitch? In order to get the arms to go down the easiest, leave the engine off, stand on top of the right lift arm and hold the front long outside hydraulic lever as far forward as it can go (this is important---as far forward as it can go). The lift arms will NOT go down on their own weight and they will also work upwards with the engine running at full throttle with no weight on them. That's just the way it is.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisUpstate Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2011 at 7:17pm
Dr. Allis,
Thanks -  was hoping you would reply.  Actually, I converted it over to factory 3 ph from a 185 salvage.  I have the link rod from the 3 ph tortion bar connected to the Traction Control, but the belcrank has some free play, and there is also free play between the piston coming out of the Traction Control module and the steel driving piece coming off of the Traction/Position control linkages.   I can jump up and down on the lower hitch arms, while pushing the lift lever all the way forward (or wiring it forward), and can't get the arms to lower.  If I wire the lift lever full forward, and use a long 2X6, I can force the arms down with considerable effort.  It doesn't seem to matter if the tractor is running or not.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2011 at 7:40pm
Remove the cover on the rear of the valve stack (two allen head bolts) in-line with the TractionBooster/Position Control plunger. Then take a hammer and punch and gently drive it all the way forward........penetrating oil it from both sides and work it in and out to be sure it goes all the way forward and it shouldn't touch the control finger on the front side.....there needs to be some daylight between the finger and the plunger.
This page was generated in 0.043 seconds.
