AC compressor for 8050
wekracer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Topic: AC compressor for 8050
    Posted: 24 Jun 2011 at 7:25pm
I need a little help.  AC compressor went out of the 8050 just as i finished planting.  Allis dealer wanted $650 for a new one.  International truck dealer listed one for $130 that was supposed to fit.  it was the same compressor but had a different pulley.  i was going to change the clutch but the shaft was a different size.  i was wondering if anyone else has a part # or can sell me a new one for a decent price.  i forget the manufacturer name but it's the pancake type like GM used.  i think it's henderson or something like that.  any help would be appreciated.
PS  it has a new expansion valve and the last day i ran it it was at 170 on the high and 90 on the low and leaked down over night.  old pump had oil and dirt around the shaft where it was leaking.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2011 at 7:35pm
When you say went out, do you mean it leaked or seized? Loss of the oil in the system from leaks is usually the cause of seizure. In that case you need to check the system for metal particles.
Mike Kroupa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike Kroupa Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2011 at 10:51pm
You have a GM R-4 COMP. with the ag clutch, not very reliable. If it were mine I'd change it back to a GM A-6 with the ag clutch.You'll need to change the mounting brackets, early 8000 series or 7000 series brackets. I think the R-4's used O-ring fittings so you should be ok there. HTH, Mike
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2011 at 7:13am
A&I sells a kit to convert it over to a different compressor which is a much better compressor than GM.   MACK
TJ Shaw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TJ Shaw Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2011 at 7:19am
AP Air has quite a few options.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2011 at 8:04pm
Thanks for the input.  that is what i was looking for.  i will try those two places and see what i come up with.  i knew i had to be able to get a new one for less than $650.
and when i say it went out, it just wasn't building head pressure, so i assume it was bypassing in the pump.  it didn't start leaking untill the last day or two.  i would just charge it untill it cooled enought to get through the day.  it is getting the engine rebuilt this winter along with the AC system.
AllisFreak MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2011 at 9:20am
My 6060 had the Harrison (GM) style like you are talking about. She stopped cooling and about 2 days later it locked up tight. Switched to a new Sanden from AP Air, been working good so far.
dave63 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave63 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2011 at 10:40am
The Sanden is a good reliable compressor.
The universal answer to all questions is yes, how much do you want to spend?
