"C" carb adjustment
Larry(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Topic: "C" carb adjustment
    Posted: 24 Jun 2011 at 6:08pm
Trying to get the C running after the water issue (fuel).  still will not run.  it will hit on a couple, then die.  I took air filter off and tried a shot of gas right in and same result.  I did take carb off, apart,cleaned,reassembled and same thing.  Any ideas.  I did not move air and fuel screws, but was thinking about starting over with those setting and seeing what happens
Thanks, LH
'40 WC puller, '65 770 Ollie
*ALLIS EXPRESS contact*
I can explain it to you, BUT I cannot understand it for you!!
Tedin NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tedin NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2011 at 6:19pm
Check for fowled plugs, and spark at all plugs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2011 at 9:38pm
Could very well be a plug problem. Poor fuel can put a glaze on a plug in no time and they will not fire through it.
Ohio Orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ohio Orange Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2011 at 10:07pm
Poor Spark ! If it wont fire with what you did , it's in the ignition .
Edited by Ohio Orange - 24 Jun 2011 at 10:09pm
