allis chalmers dd grader
q4016lanz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote q4016lanz Quote  Post ReplyReply Direct Link To This Post Topic: allis chalmers dd grader
    Posted: 23 Jun 2011 at 10:54pm
We use this old grader on the farm cheers john
DonBC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonBC Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2011 at 12:12am
Great looking DD grader John. I have a D grader about the same vintage. Yours looks as if it has had a fairly easy life because I don't see obvious repairs to the pipe frame. My grader and several others that I have seen have all had places on the pipe frame where they have cracked and been welded and reinforced. I see that you have a ripper mounted at the back. I mounted a ripper from a JD 350 crawler loader on the back of mine as I often have to deal with tree roots and rocks. I have also added power steering to mine, added a foot controlled throttle to make it easier to double clutch when shifting between 3rd and 4th gears and moved the hydraulic pump to be driven off the end of the crankshaft. Is your left rear wheel loose or is there just some oil leak. When I got my grader one wheel on each side was loose on their axle. The nuts where tight but the washer under the nuts had come up against a boss at the end of the taper on the axle before the hub could be pushed completely onto the taper. It had been run that way for a considerable length of time as the tapers and keyways all needed to be redone . The machinists cut me cupped washers so that the nuts could properly push the hubs onto the tapered axles. The reason I mention this as I exchanged some emails with a guy that encountered a similar problem with an Allis M65 grader. It had to be a manufacturing defect.
Post Options Post Options   Thanks (0) Thanks(0)   Quote q4016lanz Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2011 at 6:40am
 Hi Donbc i will check that wheel it has a ford diesel motor my hyd pump is belt drive  it is how i got it 8 years ago. When we got it the motor was seized had got water in it from the rain we pulled it down honed the bores and had it runing in a few days very handy on the property and i would love power stering but you cant have every thing. cheers john
This page was generated in 3.867 seconds.
