Planter Almost Done
wkpoor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkpoor Quote  Post ReplyReply Direct Link To This Post Topic: Planter Almost Done
    Posted: 23 Jun 2011 at 9:49pm
Still got to finish the fertilizer drops. I have the dividers to install and the mud scrapper and I'll be about ready. If it ever stops raining and dries up when I'm not working. Either way I'm putting seed in the ground if its 4th of July. All I did for now was clean it up and put flat black on some corrosion sensitive areas. I'll take it down and blast and paint sometime later in life. Got only one good fert. drop so going to try flexible exhaust pipe or something or the such. Did find a rubber boot that fits perfect to get me started. Should have bought the set at the auction last year at Dales'. BTW that tractor has the original batt box without so much as a pit in the metal and still has top and bottom insulater plates. The front grill and floor pan are dead nuts perfect. And those are the origianl tires it was sold with, no cracks at all. I'm betting the bulbs in the lights (all 3) are original.
Edited by wkpoor - 23 Jun 2011 at 9:51pm
jhid View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jhid Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2011 at 9:52pm
looks good! make sure to get some pictures of it working
red and green are nice for christmas, but orange is all year round
http://www.canadianantiquetractor.com/tractorforum/
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2011 at 10:28pm
That is super neat! wish I could find a reasonable one!
Pastor Mike in Iowa
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkpoor Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2011 at 10:43pm
Pastor Mike in Iowa
What do you consider reasonable?
Wil M (NEIA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wil M (NEIA) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2011 at 6:39am
Very nice planter and CA!!! I wouldn't even think about re painting it in the future.  That looks great! I wish my CA and planter's paint looked that good.
I had 1/2 of the metal fertilizer drops on my planter and I used stiff radiator hose to go between the drops and the runners.  You would just need to figure out what to use to go from the bottom of the fertilizer can.  I would look beyond Allis parts, you may be able to find something from other manufacture that used metal drops on grain drills or planters.
Wil
"Yet there are soulless men whose hand and brain tear down what time will never give again." Anderson M Scruggs
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkpoor Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2011 at 2:17pm
I just might have found the perfect solution to the drops. Flexible metal pipe. Bends easily and maintains a smooth interior wall. Most hose has ribs that would impede the granules from smoothly dropping. This looks like it may work better than original. I'll report back.
