Allis C carb
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Topic: Allis C carb
    Posted: 23 Jun 2011 at 9:33pm
I am trying to clean rebuilt my C carb. It is a Zenith 8581 according to the tag. I tried to get the main jet out, but it won't come out, now I can not even grab it with a screw driver now...any suggestions on:
1. How to get it out with out ruining the lower part of the carb?
2. Where can I get a new main jet?
Thanks
Pastor Mike in Iowa
Tony.Or View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony.Or Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2011 at 9:56pm
Mike  !  I did a quick look up on that  carb  number , wasn`t  on my list,  but  8561 was  there   for  1940  B .  ac  number  was 206989.  ..        Try  Albert  for  the jet  1-800-589-2426 .. Tony
wkpoor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkpoor Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2011 at 10:03pm
Try heating around the area with one of those little butane blazer torches and make sure you have the exact fitting screw driver if you have to grind tip. Then use water based valve grinding compound or screw grab to ensure you don't slip and bugger it. I can always tell when somebody has been into a carb because they don't use the proper tools and bugger the hardware.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2011 at 10:11pm
The jet is so stuck that it is already buggered BIG time..no way a screw driver can take it out now...Tony it might be an 8561 carb...hard to tell for sure. This is off a 1942 tractor.
Pastor Mike
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkpoor Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2011 at 10:23pm
Might be easy out time then. Still I would heat it gently.
