WD45 Exhaust Leak
Osage_Orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Osage_Orange Quote  Post ReplyReply Direct Link To This Post Topic: WD45 Exhaust Leak
    Posted: 23 Jun 2011 at 7:56am
Front port leaking between head and manifold. Need to keep using tractor for a few weeks.  Has anyone had success with "stuffing" hi temp RTV in the leak as a temporary fix or does it just blow out?
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2011 at 8:06am
I used refractory (furnace) cement as a temporary fix once. Worked for a while.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2011 at 8:53am
High temp RTV will burn off in a matter of a few minutes.
JayIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JayIN Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2011 at 11:44am
Muffler Mender in a tube will last a little while. Comes in a toothpaste-like tube. Kind of like refractory cement. Wear rubber gloves- kinda hard to get off hands!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2011 at 1:38pm
If run with a leak very long, both the head and the manifold might need milled flat to make new gaskets hold. Ask me how I know.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Osage_Orange Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2011 at 2:16pm
Think I'll try the "muffler mender" first.  CW, I was wondering about head/manifold damage........tks for sharing that.............O_O
Post Options Post Options   Thanks (0) Thanks(0)   Quote JayIN Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2011 at 6:51am
I guess you could also smear J-B weld around it, should last for a while.......
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2011 at 9:52am
Jb weld will last about 5 minutes if that long. Its too much heat fot it and it will melt it back out. The muffler mender works good ive used it on several projects.
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2011 at 10:05am
My expierience with the lost gaskets usually means the manifold has wore away also. So you are gonna need to plane it anyway. I really wouldn't worry about a patch job. A couple more months aint gonna hurt the head unless of course you use it every day.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Osage_Orange Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2011 at 1:59pm
I bought some gasket material. Gonna remove the manifold and make all new gaskets.  Gee........If word gets around about me actually doing this the correct way, it could ruin my reputation.  LOL.   Thanks for all the replies and info.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2011 at 5:31pm
Well..........if you're gonna take the manifold off anyway.........you can take it to a machine shop and have it milled flat!!
Or..........you gould do like I did.......use a big ol' flat b stard file and some elbow grease and true it up the hard way!!
In any event, if the manifold is eroded away, it would be best to get it all flat again.
And........if the head has erosion, you may want to use some real good refractory cement as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Osage_Orange Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2011 at 10:55pm
Well, here it is.  The exhaust ports are about 3/32" lower than the intakes.  Guess, I'm gonna do like Brian, and use a file or angle head grinder to make them all the same level.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Osage_Orange Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2011 at 10:58pm
Brian: Where can I get refractory cement?  There are a few pits on the manifold that may as well be repaired.  Is there a particular brand you recommend?  tks.........O_O
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2011 at 3:48pm
That erosion... if that's the way it is... isn't so bad.  If I didn't have machine tools, I'd use a belt-sander and just sand it down 'till they're really close... that'll give you better results than an angle grinder... a 'flatter flatness'...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2011 at 6:28pm
O O,  Nowadays,with all the wood stoves around, furnace cement can be bought about anywhere. One of the common brands is "Rutland". As someone else said, "muffler mend" cement in the tubes is basically the same thing.
The good thing about your manifold is there is plenty of "meat" left in the casting. Sometimes (especially with the original factory manifold, the front port runner will get very thin  and portions of the manifold will have holes where it has rusted right through.
GBACBFan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GBACBFan Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2011 at 7:50pm
I'd do as Dave suggested. Work them down with a belt sander, and finish them off with a mill file. If you have one of these it would work pretty well.
are genuine." - Mark Twain
Onslowe in Mo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Onslowe in Mo Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2011 at 8:14pm
Hard to beat what a decent machine shop could do.  I had a couple of WD manifolds planed awhile back for $10.00 apiece.  Got them all nice and flat.  Sure glad I found that place!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Osage_Orange Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2011 at 10:48pm
The reason the intake ports are so far above the exhaust ports (in the pic) is because the steel rings and part of the intake gaskets were still on the manifold.  So.......very little work with a large file made all of them even.  Will fill in a few of the pits with refractory cement, apply new gaskets, and reassemble everything.  Boy, do I feel STUPID! (but relieved, lol).  Thanks for all the info and comments..............O_O
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2011 at 6:28am
O O, I always say it's better to be lucky than good! That surely makes the repair a LOT easier. :)
WC, CA, D14, WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2011 at 8:52am
Nothing stupid about that. None of us caught it and I can see it now that you mentioned it. The picture looks like the left exhaust port drops off to the outside edge. That is where they start leaking and eroding. It won't hurt to check or file the side of the head too, looking close at the outside edges to be sure they don't drop off some.
