'39 B hand brake sticks?
Mark in Iowa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark in Iowa Quote  Post ReplyReply Direct Link To This Post Topic: '39 B hand brake sticks?
    Posted: 23 Jun 2011 at 7:33am
One of the hand brakes sticks back when you pull it and you have to manually push it back forward. Suggestions on what to do?  Thanks
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2011 at 7:58am
If you don't have a broken spring you have a rust and crud problem.
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2011 at 9:51pm
There is a spring that hooks over the brake adjusting bolt and the other end hooks into the oval slot on the front of the housing. They are special springs and cost about $8- $10.00 each. Bob
wkpoor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkpoor Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2011 at 10:26pm
Plus 2 on a little bit of both.
