160 Allis
joem View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote joem Quote  Post ReplyReply Direct Link To This Post Topic: 160 Allis
    Posted: 22 Jun 2011 at 7:41pm
We just bought a 160 A-C and have found a few problems. Can anyone tell me why the  three point arm will not raise- we have changed all the filters and cleaned the strainer and also have put a new hydralic pump on. The will raise will slow if ran wide open but they will not raise any kind of load. Thanks for your help in advance.
kip in cny View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kip in cny Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2011 at 8:08pm
You cleaned the filter by the gear shifter ?  If so how dirty was it it may be pluged again.
160 CA 920diesel 5020 HD-3
joem View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote joem Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2011 at 8:40pm
I tried it as soon as I cleaned the strainer and it did not make a difference.   I guess I will keep looking. Thanks!
BrianC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2011 at 11:42pm
Mine will sometimes lose the prime on the pump. Then no hydraulic pressure.  Then no 3-point action, or very shaky 3-point lift. They used different pumps and lines between the standard, basic and One-Sixty vs. 160 tractors. You can go to www.Agcopartsbook.com , view books as guest, 160 model, Agco Allis brand, select 160 tractor. Look at the hydraulic Strainer & Lines section, page 148.  IF you have a compatible browser- sometime I get picture, sometimes not. They used to use SVG, now Silverlight for graphics, ahhh.
There is a strainer on the suction side, and a high pressure filter in the output side, on the radiator bulkhead.  If you replaced the pump with a good one, does it make pressure?
There is a port in the fitting on the top of the pump. I think it is meant for a high pressure test gage.  I started mine once with that plug out, and oil came shooting out 25 feet. I guess it makes pressure! This is very dangerous, so don't do it. High pressure oil can puncture your skin, then you die from infection. Or poke your eyes out. Just think worst imaginable from the Bible, worst imaginable.  At minimum you get a one gallon oil mess faster than you can shut down the tractor in an oil fogged,  slip-sliding unsafe panic.
If it doesn't make pressure there may be an air leak on the suction side. I count 6 potential places for air leaks: 3 o-riings, two hose clamps, and the cover for removing that strainer where the catch magnet is.  Mine has one of the 4 studs/acorn nuts on that cover missing, this may be my leakage problem, ya think?. However, if I keep the hydraulic level on the high side, I don't have a problem. It is an aluminum pump.  Other than this now rare problem, and 5 year batteries, this machine has never failed. 40 hp Perkins diesel, great fuel economy and an oversize cat 2 hitch. Not bad for a "French" tractor. A little noisy for me, I like mellow 4 cylinder gas sound at 1200rpm. I think AGCO has all manuals in stock.
So here is my question for anyone: Manual clearly says,  at two places, to "use Allis Chalmers Power Fluid 106"  in the hydraulic/transmission system and also in the power steering system. What is that ? I spent hours trying to find a cross reference to Power Fluid 106.  Maybe I can't Goggle that well, but it don't exist on the web as far as I am concerned. JD dealer guy couldn't find it in their printed book either. So I use universal tractor fluid.
John WV View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John WV Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2011 at 8:35am
Brain, The manual you are talking about is it for the 160? My manual said to use 10-30 in the hyd./trainsmission . and 10 w in power steering. my 2 160's was made in 1970. That is all I ever used and never had trouble. I have replace hyd pump on both tractors. main thing keep all filters clean. one has 4845 hours on it (brought it new)  and the other has 2707 on it
joem View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote joem Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2011 at 9:08am
Thanks Brian I will check it out and see what I come up with. I will keep you posted.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2011 at 10:51am
Mine is a 1972, 3900 hours on it.  I have several manuals for different years. One of them does say to use 10-30wt in the transmission/hydraulics. However, the pictures in that manual show a different hydraulic system than mine- piping, pump, filters are different. My manual calls for Allis Chalmers Power Fluid 106. Even AGCO dealers don't know what that is (at least the two I asked). They suggest modern Power Fluid 821 would work.  What are the essential specs for this kind of fluid-non-foaming, non-detergent, right viscosity?
MarkJ_Indy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarkJ_Indy Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2011 at 11:26pm
I have a 160 that I had fits with the three point hitch, had sat for probably 15 years.  As soon as you started the engine the hitch went to the top, had to release hyd fluid from the system to get it back down.  Finally found the inside piston on the control under the seat was the problem.  When you look at the manual on that control there is an inner piston with little variation in the line spacing so it's hard to tell it's a seperate piston.  If you're still having problems that control would be a spot to check.
mtanut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mtanut Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2011 at 4:09am
Going through the same issue with a 35 ferguson, it is the cylinder and piston under the seat.
I have a 185 Allis, 6060 Allis, Model K gleaner, SMTA ferg 35, ferg 20 (paps first tractor, Allis B (wife's)John Deere 240 skid loader and a bunch of the usual farm stuff.
Eric NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric NY Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2011 at 4:35am
Check all connections on the suction side of the system.........that is where I found my similar problem to be.......specifically the 2 line clamps in the bell housing area. Good Luck, Eric NY
This page was generated in 0.099 seconds.
