Fuel Tank Liner
Brian IA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian IA Quote  Post ReplyReply Direct Link To This Post Topic: Fuel Tank Liner
    Posted: 17 Jun 2011 at 7:04pm
Does anyone know if there is something you can pour into a fuel tank to seal it up?  I have friend that has tank but it's full of rust inside. Is there some kind of liquid liner that can be poured into the tank to line it?  Or is there something we can do to remove the rust from the inside of the tank?  Any ideas you have would be great!!
Brian Lindsay
Boogerowen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boogerowen Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2011 at 7:14pm
I have had a couple done and basicly what they do is use some kind of acid to remove the rust and as soon as the tank dries inside they put some kind od epoxy liner in and then let it cure 48 hours before using. Both tanks are great now, and were very rusty inside before...
TomMN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomMN Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2011 at 7:14pm
dave63 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave63 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2011 at 7:24pm
I used red-kote  it works great and was easy to use.
The universal answer to all questions is yes, how much do you want to spend?
Dipstick In View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dipstick In Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2011 at 8:28pm
Muratic acid from a swimming pool place, some Walmarts, Lowes, Menards, etc. takes out the rust, should neutralize with baking soda.Rinse out well, dry well, then use Red Kote, let it dry well according to directions and you're good to go.
Ed in TX View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed in TX Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2011 at 8:49pm
I've sold Kreem for over 25 years. If it's done right, it's a great product. If it's done wrong, it will cause more problems. You should be able to find it at any motorcycle dealer or repair shop. Complete kit costs about $30.
Auntwayne View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Auntwayne Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2011 at 10:25pm
      We just rebuilt a 37 Minnie that we retrieved from Oklahoma that sat outside for the better part of the last half century, the fuel tank had some pin holes, we took it to our radiator guy, put in a coating , sealer, no problems what so ever. It is easier to fix properly than you think.
Bull View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bull Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2011 at 11:42pm
I used Red Kote on my CA. There were a couple of holes too large to seal so applied JB weld in them before  using the Red Kote.
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2011 at 11:47pm
Il second or third the Red-Kote. Ive done it to my WD45 and have not had a problem in over 10 years.
HagerAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2011 at 1:03am
I've used Northern Tank Liner many times with excellent results.  Got it at an MPE store.
