Pat the plumber here is your 172
Auntwayne View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Auntwayne Quote  Post ReplyReply Direct Link To This Post Topic: Pat the plumber here is your 172
    Posted: 16 Jun 2011 at 7:00pm
Pat, wanted to show you the brushhog for some time.  Here are the pictures!  More if you want them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2011 at 11:19pm
Thanks for posting, Thats one long PTO shaft on that.Looks just like the one I use. Is the PTO shaft original ? Mine is set up same way but beleive there is a piece missing where it mounts to drawbar and splits the shaft into 2 shorter sections.
On our farm as kid we had the same set up with the wheels behind,Better for mowing close to objects but heavy on drawbar and harder to hook up.The one I use now has the wheels on the sides in the middle,balances nicer and easier to hook up.No jack needed. I like the tires,,,No flats
Again thanks for posting, love to see orange equiptment still in use.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Auntwayne Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2011 at 8:17am
      I am going out to the farm today, and, I will take pics of the PTO for you, yes it is all original, just beefed up !!! The wheels were in the middle back about 3 years ago, one guy could grab the tongue and pull it around the shed all day, perfectly balanced. But, youcould not get as close to fences, etc. Now that the wheels are to the rear again, it has to be jacked up as it would take a small (large?) army to lift the tongue. You cannot see the dual knives very well, will try to get a better pic today .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Auntwayne Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2011 at 8:53pm
       I am not sure what you mean about a piece being "missing", please elaborate. I did measure the PTO shaft though, it measured 74" start of yoke spline to mower clutch,is that what you meant?
acwdwcman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acwdwcman Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2011 at 8:57pm
i used to have one of those.. before it went to the scrap yard.... i couldnt save it.. rust holes all over.. and the gear box was totaly broken..
wd with a freeman model 90 trip loader, wd45, 38 unstylled wc, b 10 garden tractor and 2-14 ac trip plow. grandpa has a 56 wd45. wd. allis chalmers snap coupler blade and 3 bottom snap coupler plow
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2011 at 9:05pm
Here is a pic at an auction of one in almost perfect condition
See the metal bracket near front of PTO shaft.Bolts to drawbar and hinges back and forth.U joint splitting shaft into 2 smaller sections
Post Options Post Options   Thanks (0) Thanks(0)   Quote Auntwayne Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2011 at 9:34pm
      You are talking about a "carrier bearing" correct ??? The only part that I do not understand is why you have a shorter PTO shaft and still have a carrier ??? I will post pics having more clarity. I also see that you have a shield. I will definitely grab the original  owners manual tommorow to verify your set up, you are stock, right ???
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2011 at 9:39pm
Pat - I have 172 in original condition and the PTO shaft is set up like the one you just showed in the picture.  I also have the factory ratchet to go on the other side from the hydraulic cylinder to use as a depth stop (or it can be used in lieu of a cylinder, just no raising it from the tractor).  You can see it in right side of this photo i the background.  I wish mine had the optional chains front & rear.  Mike
Edited by Skyhighballoon(MO) - 17 Jun 2011 at 9:41pm
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Post Options Post Options   Thanks (0) Thanks(0)   Quote Auntwayne Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2011 at 10:13pm
    Out of curiosity, what year is your mower ? I have never seen the 172 with a PTO metal guard, and, I have never seen one with chains ???
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2011 at 10:33pm
The mower sitting by itself is not mine.I took a picture of it at an auction back in March.I should have bought it but set my limit at 500.Afterwards I realized should have valued it much higher.Where else are you going to find one in as good as shape.Sold for 650 I believe.I should have gone up to a 1,000.
The one behind WD45 is mine and the "carrier bearing" was gone long before I got to it.I bought a slip clutch and long PTO shaft at TSC.I noticed yours did not have the carrier bearing on it either.Mine works fine just have to have a bolt with a flat top for a hitch pin so the PTO shaft won't hit the top of the hitch pin.Believe that original carrier bearing held the shaft up and kept it off hitch.Love those tires on the back of yours.My dad had some on ours back in the day.Best money he ever spent.
Mike ,,, that ratchet set up reminded me of an accident I had.I was working ratchet on ours when I was 13 and it came apart.My feet were under edge and mower fell on my foot(no safety chain).Well there I was in pain and stuck.My brother saw me and ran over and what did he do? He jumped on mower and tried to put ratchet back together.Ouch!!!.Finally my brother my dad and I all lifted and got my feet out.Then my dad got his fingers stuck and we had to lift again to get him out.Both my feet swelled up like grapefruit but X rays were negative.Dad put a hydraulic cylinder on after that.
Edited by Pat the Plumber CIL - 17 Jun 2011 at 10:36pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2011 at 11:14pm
I have the same cutter in the 3-point version and glad to see how the safety chains are mounted before I added some to mine; now see how they extend out further in the middle and that is what I will do.
Found mine for 350.00 and it has cut alot of rough stuff behind a D15IIG, including trees up to 3" OD. D15 would handle one foot wider cutter and that would help cover my tires better, although current unit is heavy. Rarely floats the front end and I had 2-3/8 pipe mounted on each side as runners. Keeps cut at 6" minimum and it is all my D15 wants when you get into grass above the hood in 2nd gear.
Gear box is hell for stout on these units.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Auntwayne Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2011 at 11:34pm
     Took some good pics at the farm today of the combination of hook ups available from A/C Owner's Manual, I know you will like them !!!Great info. Will post after lunch Sunday.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Auntwayne Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2011 at 8:35pm
James Bond needs a better digital spycam!!!  The mower serial number is 544, very early do not know the year, anyone know?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2011 at 9:03pm
Does not look like the 172 came with a carrier bearing on the PTO shaft.Maybe early years did not and later models did.Would think they figured out that shaft may be too long and changed design.The pic of the one at the auction was a 172. The one I have now (the one behind the WD45) is a 172 also.Here is a pic of ser # on mine.Not far off yours
Thanks for posting pics of manual.Great info.Have seen 5 foot 160 model with a snap coupler but never a 172 with a snap coupler,may have been too heavy.Someone on here said something about a 3 pt hitch on one.I have thought if I took wheels and axle off.Bolted on some angle iron and fabricated a 3 pt. hitch.Make up a tail wheel and away I go... Ahh too much work and I don't want to dismantle a fairly original A/C mower.I imagine I will get a 6 foot woods w. 3 pt hitch and retire this A/C before I wear it out.Still works good and gear box is still in good shape.It will not go to china!!!
Again thanks for posting pics
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2011 at 9:27pm
I have a 160 snap coupler mower. It has a 1 piece shaft too. Looking at the pics of that sales brochure, it looks like maybe the slip/overrun clutch might have been optional? I just got all of the seals for the gear box, and pins and springs for the overrun for mine from Sandy Lake.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Auntwayne Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2011 at 9:49pm
      I took a lot of pics of the PTO ,for some good old forum info, and took a lot of pics with the digital cam, felt like a spy vs spy kinda guy, taking pics out of the IT BOOK, learned a major lesson in photography, DO NOT TAKE PICS ON THE EAST SIDE OF THE MACHINE SHED AT 5 PM !!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2011 at 10:03pm
On my digital camera there is a close up setting.I found a stand for it and cable trigger(or use 2 second delay).This keeps camera from shaking while taking photo.Place picture you want to photograph flat on table.Place lights on sides to eliminate shadows(no flash).My stand will rotate 90 degrees so camera is aiming down.this set up is very good for copying photos onto digital format.Hard to do with manuals and books as the pages want to curl.
Thanks again, keep those photos coming.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Auntwayne Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2011 at 10:15pm
       "KEEPS THE CAMERA FROM SHAKING" ,I am pretty old, but, no camera of mine ever "SHAKED".
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2011 at 11:49pm
Early (starting about 1959) 160 and 172 mowers were built by Danuser Machine Works in Tulsa, Oklahoma.  in 1962 Allis moved production in house to the LaPorte factory.   They kept the 160 and 172 model numbers but the mowers were entirely different...from Norm Swinford's book.  This accounts for the PTO shaft differences among other things.  Mike
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2011 at 7:17am
Thanks Mike.Good info to know.Mowers are over 50 years old and still working.We must of had a newer one on the farm.
This page was generated in 0.230 seconds.
