Allis B Adjustable Front Axle Tie Rod?
Toby View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Toby Quote  Post ReplyReply Direct Link To This Post Topic: Allis B Adjustable Front Axle Tie Rod?
    Posted: 12 Jun 2011 at 10:00pm
I have a 1949 Allis B with an adjustable front end and I need to replace the tie rod and the ends... Not having any luck locating anything!!! Looks like all the replacement parts are for the wishbone style front end.
Can anyone shed any light my way on what to do?
It does look like the WD45 may work, but may have to ream the holds on the steering arms to fit and cut the shaft and tube to fit...
Has anyone run into this problem?
Please let me know...
Thanks,
Toby Wellborn
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2011 at 7:20pm
Let me know what you learn on this. I have one that will need the same. I never thought about them being different.
Toby View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Toby Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2011 at 8:47pm
I will let you know Thad when I find out...
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2011 at 9:17am
I believe they are the same as a WD45, just have to cut them to the proper length.
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2011 at 9:33pm
the WD steers from the center, same as a C or CA, and the B steers from the left spindle. The tie rod ends should be the same, 5/8", but you would have to couple the 2 pieces together to make one. Bob
