CA Hand Clutch lever problem
allis restorer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis restorer Quote  Post ReplyReply Direct Link To This Post Topic: CA Hand Clutch lever problem
    Posted: 12 Jun 2011 at 8:28pm
On my 1951 CA the bolt that holds the hand clutch on came out and the threads are all gone in part where the bolt threads into. I need help on how to fix this problem. Any help is appreciated, thanks Steve
Go orange or Go home!!
redline View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote redline Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2011 at 1:49am
I had the same problem, and a heli coil thread insert fixed it right up. The biggest trick is finding the right size drill bit, since you will be over the 1/2 inch size to put in the oversize threads to hold a heli coil. I couldn't find a bit, so I wallered the 1/2 inch bit around in the hole a little and the new thread tap was able to cut threads then. I am not recommending that step, but that is what I did out of desperation.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2011 at 10:30am
I think it takes a 33/64's drill for that helicoil. HTH Tracy Martin
This page was generated in 0.124 seconds.
