WD front wheels_substitutes
Osage_Orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Osage_Orange Quote  Post ReplyReply Direct Link To This Post Topic: WD front wheels_substitutes
    Posted: 10 Jun 2011 at 2:04pm
Looking for some extra wheels/tires to have as "standby units" for my brush hogging season.  Actual AC wheels (when advertised) are either too far away or too expensive.  There must be some car/truck units that will work.  Tks...............O_O
Tom Miller (IA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom Miller (IA) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2011 at 8:24pm
My dad told me if memory serves me right that old buick wheels fit cause he said he used them on his D17 loader tractor when he was a kid because they where wider.
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2011 at 8:50pm
  have new and used wheels  your choice    1-800-254-3116
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2011 at 8:55pm
Osage I use 15" tubeless on mine so I can plug them. I think they are Buick they have little spring clips on them for hubcaps. Gotcha a good locust thicket do ya?
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2011 at 9:07pm
We were told the 1950 Buick wheels fit. We have them on two WD45's. I was told 1950 was the only year that will work. Hope it helps.
Don(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2011 at 9:08pm
Just curious, wonder how front steel wheels would work??
GBACBFan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GBACBFan Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2011 at 9:41pm
For that use, wheel adaptors to a standard car rim may be a solution. Low speed, under $50/side, and you're ready to go.
Edited by GBACBFan - 10 Jun 2011 at 9:50pm
are genuine." - Mark Twain
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2011 at 10:40pm
Front wheels from a Massey Harris 44, 33, 444, 333, 101 and 102Sr. are the same if you have access to any of those.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2011 at 12:38am
They are probably standard ag rims. If car rims fit, likely 5 bolt, available in several widths, diameters, offsets, and strengths. Used for tractor fronts, implements, and hay racks. You need to use the same offset or back spacing to keep from having tires rubbing on the spindle.
Section F of the downloadable catalog from Baum Hydraulics (www.baumhydraulics.com) shows a couple in 5" and how to measure the hole centers and the other details. Date 3000 on the page says 30% discount off those prices.
Other farm dealers like Shoup (www.shoupparts.com) and Sloan Express (www.sloanex.com) have a greater selection. Gemplers (www.gemplers.com) and Miller Tire probably have the widest selection easily found on line. These implement rims are also found in salvage yards and at farm sales and consignment auctions, and can be bought at some tire dealers that handle farm tires.
The bolt circle for ag rims tends to be larger than for cars or pickups. But you can check with a tape once you know where to measure the 5 bolt rims.
Most tractor makers bought their rims using an SAE standard ag rim.
The appearance of the rim disk will vary with offset and with the manufacturer.
Gerald J.
Adam Stratton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam Stratton Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2011 at 7:27am
I know from experience that the front wheels from a SC Case will bolt right up.  They are 15" rims, and are solid cast, so you get about 100-150 lbs of weight as well.  I have 2 sets laying around here (just south of Lamar) if you are interested. They are less fun to change when you have to, but if you have a mounted bush hog, sometimes the extra front weight is worth it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2011 at 1:43pm
Might want to buy a set of these used aircraft tires.   Supposed to be so thick that you won't get any flats from thorns.   I have a set on my D17 as it has a loader on it and they are some stought tires.   I had a bear getting them on the rims, but I'm sure they'll be the last set that I ever put on that tractor.
Here is the link:
mike a View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mike a Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2011 at 8:58pm
use donut spare tires from cars.they are cheap.
