Series I D17 Hyd linkage?
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Topic: Series I D17 Hyd linkage?
    Posted: 09 Jun 2011 at 10:43pm
My series 1 D17 seems to have a linkage problem on the hydraulics. When you start the tractor the lift arms raise no matter where the control lever is set and the arms won't drop after the tractor is shut down even in the lower position. They will drop over night but go up again as soon as the tractor is restarted.
Is there a pin or something inside the torque housing that could have fallen out? The external linkage works fine. I haven't had a chance to look at a manual yet.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2011 at 6:15am
Traction Booster lever must be clear down AND the link rod under the belly that connects the hyd pump lever to the drawbar load spring has to be there and adjusted properly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2011 at 7:38am
TB lever is down, Main hyd lever is down but pump still is running. The linkage underneath appears unchanged. The hydraulics had been working fine, but when the tractor was started one morning a couple days ago the 3pt came up and wouldn't come down. Going to get the book out today and tear into it.
