Will a WD pull a 3/14 plow?
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Topic: Will a WD pull a 3/14 plow?
    Posted: 09 Jun 2011 at 8:57pm
Will a stock wd pull one ok? It would be snap coupler.
monitordoc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote monitordoc Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2011 at 9:01pm
 I have pulled a snap coupler 3/16 with a WD for many years. later I updated to A d-17 pulling 4/16.
WD,D17-S4,180,D21
Jamie (KY) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jamie (KY) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2011 at 9:02pm
D14's were designed to pull 3/14's so I'd say yeah. I'm not an expert but just my opinion.
Just when I thought I was finishing my "honey-do-list", she turned the page!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote monitordoc Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2011 at 9:03pm
 I should add that it depends on soil type
WD,D17-S4,180,D21
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2011 at 9:03pm
My uncle used to pull 3x16 mounted with a stock WD. What ya got going?
I would say in lighter soils or mellow soils it can but probably not in gumbo. If it had a 45 crank put in it then it would for sure. Dad used to pull 3x16 mounted in gumbo soil in 2nd gear but it worked the snot out of it. In our soil now it breaths easy pulling 3x16 in 3rd gear.
Wink
I am a Russian Bot
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2011 at 9:06pm
It would be in mostly sandy soil.
JM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JM Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2011 at 9:08pm
My dad told me he once pulled a 3-14s with the C in second. He said the gears sounded like they were gonna bust, he would have to go to 1 st in a hard spot. Good soil in midwest ohio.
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2011 at 9:12pm
   This is one of those questions that is pretty specific to the ground being plowed. The ground around here no way. That don't mean it won't work were you are.
http://www.rumelyallis.com
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2011 at 9:12pm
sand it would pull like it wasn't even there in 3rd full throttle
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
Auntwayne View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Auntwayne Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2011 at 9:14pm
    We pull a 3/14 snap coupler since bought new, and, want to buy a 4 bottom because it still will pull with ease, go for it !!!
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2011 at 9:58pm
My WD plays with a 2-14 WD pick up plow (mounted but not snap coupler) but had a heck of a time getting traction with an Allis pull type 2-14. No weights or liquid ballast and worn tires. I think it would handle a 3-14 mounted plow with added wieght. My WD45 has no problem with a 3-14 snap coupler plow with 1 pair of rear weights but it has more HP too.
Edited by Dave in il - 09 Jun 2011 at 9:59pm
dudley wallace View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dudley wallace Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2011 at 6:58am
my wd will pull a 3/14 mounted plow the 3/16 inch plow i have has newer  385 bottoms on it and it pulls better just to big of a plow it was made for a d-19
a member of hendricks county antique tractor and machinery association club.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2011 at 9:59am
Yeah, pretty subjective question.  If you put ANY plow in 4 yards of concrete... nothing short of an excavator will pull it... it was a pretty common setup for those tractors, so you can figure that under a good chunk of conditions, it probably will.
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2011 at 10:04am
What kind of dirt you in?
Terry GA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Terry GA Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2011 at 2:48pm
It will in sandy soil....put a 170 govenor spring in it and let her roll!
I couldn't repair your brakes, so I made your horn louder.
Ryan Renko View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2011 at 6:36pm
It depends on soil type but our WD has m&w pistons in it and it would pull that plow all day and night long!! Ryan
Post Options Post Options   Thanks (0) Thanks(0)   Quote Auntwayne Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2011 at 8:36pm
We are in god's country, central Illinois, good old black on the flat and hard ass clay on the hills !!! The tractor does not care .
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2011 at 9:24pm
If you are buying a SC 3 bottom plow don't worry about pulling it. If you have trouble, you can remove the middle bottom and have a 2 bottom plow so you can plow in 3rd at an idle.
Richard S View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richard S Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2011 at 3:25am
Years ago my brother was farming with WD's.  He told me that, in the same amount of time,  he could plow just as much ground with a two bottom (higher speed) as he could with a three bottom  (lower gear).
wkpoor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkpoor Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2011 at 7:39am
That's an interesting thought. I would like o see a chart on that. The numbers might come together after say 5acres. However surely the mfg's plow ratings have taken that into account to maximize a tractor's potential to do work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2011 at 9:33am
The "manufacturers " rating was for 2 bottoms. The WD was a pin hitch tractor and I have never seen a 3 bottom pin hitch plow. I suppose there might be a few around, but there are a lot more 2 bottom WD plows
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2011 at 9:51pm
I had a snap coupler 3 bottom for my WD and it just anchored the tractor once it got in the ground....the traction booster just lifted the front end up, but that was in the concrete-like sod of SW MN. Put on plenty of weight regardless.
acwdwcman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acwdwcman Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2011 at 9:54pm
i have with mine
wd with a freeman model 90 trip loader, wd45, 38 unstylled wc, b 10 garden tractor and 2-14 ac trip plow. grandpa has a 56 wd45. wd. allis chalmers snap coupler blade and 3 bottom snap coupler plow
Don M SEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don M SEIA Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2011 at 12:17am
I have both, a 2 & a 3 bottom pin hitch.  The 3 has coverboards.  We had a 3X14 on our WD, but it makes a difference in soil type , and also moldboard # or shape makes a difference, the wrong combination doesn't work well.
This page was generated in 0.258 seconds.
