Wrong Color, but...
Greg_WJP_(WI) View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Greg_WJP_(WI) Quote  Post ReplyReply Direct Link To This Post Topic: Wrong Color, but...
    Posted: 09 Jun 2011 at 12:07am
I'm looking at buying this tractor.  I haven't seen it in person, but assuming everything works properly, what would be a fair price?
http://s1136.photobucket.com/albums/n491/shano27/?albumview=slideshow
Thanks
Greg
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2011 at 12:29am
scrap price? lol
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Greg_WJP_(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2011 at 12:33am
No, but I'll keep it parked in the back of the garage where it's real dark.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2011 at 1:06am
Green paint is expensive and that one shows signs of being worked hard. Lots more than a WD with loader!
Gerald J.
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2011 at 8:27am
Have you looked at tractorhouse or iron search to see what others are asking for that model? Also if you have a local dealer or auctioneer you can ask them? You might even find another  similar one that way, never hurts to have options.
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Greg_WJP_(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2011 at 8:36am
Dave,
I have looked at several online dealers and auction houses.  That's why I'm asking you guys.  It seems like I may be missing something.  They are asking below what I would expect for a properly running tractor with loader.  I don't post very often on the site but I read it almost every day...and I value the opinions, advise and experience of the people here.
Thanks for the replies.
Greg
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2011 at 8:42am
I worked for a builder a few years ago that bought one new. I put the first 100 hrs on it spreading gravel. I liked it very well and it was the first I ever used with an electric pto which worked awesome for post holes. When you hit the switch is stopped right then. It started good but sounded bad and knocked/hammered and smoked when started first time each cool day
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Greg_WJP_(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2011 at 8:50am
Thad - thanks, that's good to know.  I assume it ran better after it warmed up?
Gerald - possibly, but I need something better for snow removal and this has 4 wheel drive.  It will take a lot of snow to stop it if I chain up all four wheels.
Thanks, guys.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2011 at 10:20am
Four wheel drive is a help in moving snow. Those tires look worn down and tire quality is a big factor in snow. I've tried a garden tractor with snow thrower (plugged more often than it tossed snow in a wet late spring snow but was better on the average than a Ford 8N with good tires and a rear blade), the 8N with rear blade (and no chains), and a MF-135 which is a heavier tractor than that green one but without front wheel drive. The MF-135 had a MF-236 loader which was too much loader for the tractor and when a chain fell off, it could only move by bucket power. It needed a ton of added weight on the rear axle. Last winter I used the MF-135 without loader (because I moved that loader to a JD 4020) and a heavy duty rear blade. I got it stuck trying to drive forward and shove snow to the side with an angled blade. It doesn't have enough ground clearance. I may move the 4020 from farm to home for next winter, or build a plow for the front of the 135 or spin the rear blade and back into the deep snow with the 135. I did succeed in keeping the main driveway open with the 135 by being timely each snow, not letting the drifts get too tall for it to get over. It would have failed at that the previous winter.
The day the 4020 was delivered, I spent all after noon with the 135 and loader trying to open up the farm driveway. The 4020 drove over the same drifts practically as if they weren't there without chains, drifts that I failed to move with the 135 and loader. The 4020 with blade or loader I think would be far more effective because of the greater ground clearance which this little utility tractor fails to have even with FWD.
A tractor with blade or front plow runs out of room to push snow around here. The 8N could only push snow backwards by lunging at the snow which broke the lightweight blade frame once or twice. The snow thrower was best at moving dry snow but moved it further than a bucket or blade and so worked better over multiple snows. A two stage snow blower would be better and I have a walk behind to begin the opening process around here now. A loader and bucket allows stacking snow higher than a blade will push it but unless one starts the piles well back from the place to be opened a long winter like the last two can run out of space. The 24" wide walk behind snow blower can open up snow more than 2 feet deep though not very fast and for stuff that would move with the rear blade its fairly fast. Its handy for opening up the sliding door on the machine shed so I can get the bigger equipment out.
Gerald J.
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Greg_WJP_(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2011 at 10:30am
Thanks for all the info.  However, I think someone is trying to SCAM me.  When I asked to come take a look at the tractor it was conveniently located in Utah.  Yeah, right.  I don't think so.  I'm going to play along for a bit to make sure, but I guess I'm back to my searching.
wkpoor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkpoor Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2011 at 10:39am
Don't know what they are asking but those are Green painted Yanmars. I personally think the best value in used JDs is in the 5000 series and up tractors. The 5000 series have lots of power, enough weight to handle a 6' bucket with ease and can do alot of work without needing 4wd. My 5400 with the forks on can lift an Allis CA and put in on a trailer. They can be had for around 15k
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Greg_WJP_(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2011 at 10:56am
I've been looking for something for a while, now.  I'm not desperate, as I have the CA with a back blade.  But I would like a hydraulic bucket to move the snow piles once they get too big.
wkpoor,
I think a 5000 would be a bit of overkill for my little homestead.  I've been thinking something like the D14 to D17 series.  However when a good deal comes along, even a green one, I have to consider it.  But like anything, you have to CYA, first.
