3-16 White Plow Suitable for D17?
AllisUpstate View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisUpstate Quote  Post ReplyReply Direct Link To This Post Topic: 3-16 White Plow Suitable for D17?
    Posted: 06 Jun 2011 at 9:36pm
I am still looking for a good set of plows for my D17 IV gas.  Some had recommended the White plows as excellent, and I have located a 3-16 not too far away for a decent price.  However, it just seems like a massive plow for the D17.  Here is a picture of a similar plow from TractorHouse (this is not the exact plow I am looking at).
WHITE 348
Technically, the 17 should pull it, but it just seems like too much plow and too much weight.  Any opinions?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2011 at 10:06pm
I use a Model 74 4-14's snap coupler mounted plow on my Series IV.  I have 300 lbs of Hundred series stack weights out front plus 50 lbs of washer fluid in each front tire.  Works good.  If you like the plow go for it.  Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
junkman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote junkman Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2011 at 10:47pm
Think that's big look at mine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisUpstate Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2011 at 5:30am
Thanks for the pic Junkman.  I remember you had posted when you first bought the plow.  Now the obvious question, have you plowed much with it, and how did the D17 do pulling it?  Actually, I also found a 4-14 AC plow like yours at a good price and in great condition, but still think the 17 won't really handle it well under heavy soil conditions or on hills like we have.
Post Options Post Options   Thanks (0) Thanks(0)   Quote junkman Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2011 at 7:10am
Well I have got to try it out gut that is about it. I plowed a little on my dads to see what would happen, it was tall sage grass but it seamed to do fine except not in third gear. the main patch I want to plow is really grown up and extremely trashy so it was plugging up on me. I figure I will take my new disk down there and chop it up first. it might even do better now for the new tire I put on the left hand side was full of fluid.
wkpoor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkpoor Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2011 at 10:36am
Well being fully mounted will help you out. Try pulling 3-16s with a trailer plow if you want to see what that D17 is made of.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2011 at 6:37pm
Your D-17 will pull a 3/16" plow all day long!
Here's a shot of three WD45s plowing some dry rock hard black dirt last year and the WD45 in the middle is pulling a 3/16" plow in 2th gear through this just fine.
Don
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2011 at 6:41pm
I have been in the same field with Mike's D-17 plowing lots of times with this four bottom plow and it pulls it just fine.
Don
ky wonder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ky wonder Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2011 at 6:41pm
it depends on your soil type tractors that will pull 4 easy in some areas will have trouble pulling 3 in the dirt around here
i like old tractors of all colors
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkpoor Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2011 at 8:43pm
Yepper all depends on soil type and plow type (full mount, semi mount, pull type). Garantee a WD45 wouldn't pull 3-16s around here if it were pull type and I'll bet there would be plenty wheel spin as it is with the fully mounted.
